No, that's downloading an ISO, you just use the media creation tool instead
You have to be on a windows machine to do so.
So the second option "Create Windows 11 Installation media"
Got ya thanks again both - On it now will check in once doneNo, that's downloading an ISO, you just use the media creation tool instead
Totally get it, it is still an ISO, it’s just the tool mounts it and creates the boot partitions along with it.You can blame me for that one as I asked if they were using the ISOMy mind just automatically thinks "ISO" if it involves installing anything to an external drive (even though I know it's not)
As requested fully wiped using USBTotally get it, it is still an ISO, it’s just the tool mounts it and creates the boot partitions along with it.
But yeah, I still very much think in ISO terms, and exe rather than msi
So can you post the screenshot from device manager?
So you’d need to manually install the latest chipset driver from the motherboard page on the asus site
Then reboot and post another screenshot of device manager
Yep, that's itView attachment 42197I assume is the correct one?
Yep that looks like the oneView attachment 42197I assume is the correct one?
Yep, that's it
For now, can you unplug the GoXLR Mini?
And then take another screenshot please? I'm thinking those 3 are from that but we'll leave that until we're sure the system is stable.
Perfect, now install latest adrenaline for your gpu direct from AMD and then well do a couple of stresses
All downloaded and ready when you are.Install HWMonitor free not the trial
Ive just got to pop out for a mo, won’t be long
Cool, so have nothing else open.All downloaded and ready when you are.
Open HWMonitor and have it off to the side and take a screenshot with the CPU and GPU temps expanded. That gives us our idle temps
Then run furmark for 10 minutes and before you end it, take another screenshot of HWMonitor.
End the test and post screenshots of HWMonitor
