AMD issues.
I would set that section to default, not per game but globally just for testing
And then make sure you've properly cleaned Armoury Crate as previously linked
Swinny
Ive just received this message today.
Never had it before prior to now.
Mean anything?
Swinny
Ive checked a guide and can confirm my ram is set up on XMP in bios - Also ive uninstalled armoury crate - Not we will see
Mean anything?
That’s just a bug in iCue, won’t affect anything
Swinny
Honestly don’t know if I should laugh or cry at this point.
Doing a FULL DDU as we speak and reinstalling drivers with AMD experience.
Swinny
Well I genuinely think the card is bricked so I have made the painful option to buy another one 😭😭😭
Swinny
Is it not still under warranty?
Only bought it 3 months ago so yea assume it would be didnt know if it would be covered?
If it is happy to send it back
If it could just be the card alone ?
I’ve put in a RMA order and linked to here for full information
Swinny
@SpyderTracks soo just wanted to give a little update.
I have the RMA order going through on this however.
I purchased a brand new unused 7900 XTX which arrived today - installed and reinstalled drivers after removing from DDU.
20 minutes into WOW
Im at a absolute loss.................
This rig shouldnt be doing this surely.
What the hell is going on...........
20 minutes into WOW
Still think it’s a software incompatibility, don’t think there’s anything wrong with the GPU personally. But I'm always like this with any hardware issue, I always refuse to accept it's hardware until everything has been tried.
Im getting confused with another post.
Can you open control panel, go to uninstall program, then change the view to list in top right and post a screenshot?
I personally think a clean install would be the quickest resolution but we may be able to see an obvious conflict
Swinny
I’m doing a fresh install as we speak - wiping it all back to basics and then starting again
Ok, it's really important you do this by applying all optional updates once you're in windows, then post a screenshot of device manager.
DON'T install any software or 3rd party drivers yet, not even AMD, just make sure all windows updates and optional updates are applied and post a screenshot and we'll go from there
Swinny
That’s not a clean install, won’t help, you’d have to do a full clean install by booting from a windows installer USB
Ok so if using the above ISO link do I need a usb drive or anything as I don’t have one.
Or will this just download to my pc and work its magic
You create a bootable USB, needs a minimum of 8Gb
Then boot from that from the BIOS, delete all existing partitions and install to the spare space.
Little tip, if you want windows without any bloatware, set the install language to English-Worldwide
