3qtrsamericano
Fi...ling for bankruptcy.... 🙄Firecuda
The 520 or the 530? 😜Firecuda
Pffft, what do you think!The 520 or the 530? 😜
Silly me! 😬Pffft, what do you think!
Look at the numberssssss!!
That's why when I configured the I went straight for the top virtually straight away, ok I'm getting it without GPU (transferring my existing 2070super), or OS (upgraded W7 on an old PC under the bed to W10), only thing I've got for it since ordering is an LL120 for an exhaust fan, thought about some RGB strips but resistedGo big or go home!
I managed to sell myself up right through the process, the 5900x is only an extra £50, the 3070Ti was only an extra £14 (at the time) it’s only £50 for 3 more fans and so it continues!
Lols, I fully condone and respect this attitudeI've applied "man math's" or "man logic" similar to @RichLan564. It's more comforting to spec it low so that initial "hit" is bearable. And you tell yourself, "okay, I've done alright here. Close to my original budget".
Then you start to "upgrade" a little here, a little there as those "small payments" don't hurt as much as the initial build payment. 🤷♂️🤦♂️😂
Ahh, good man, keep going, there is always someting you can changeAlthough.... 👀
Figured, I'm already here. May as well buy something 😂
At this rate, I may need a fancy name for my build like @Martinr36 😏
Had you gone for an Intel build, I’d have suggested ‘The Firestarter’At this rate, I may need a fancy name for my build like @Martinr36 😏
I'm running out of things to change now....only viable option will be the GPU but that will require change to cooling and/or case.Ahh, good man, keep going, there is always someting you can change
I was glad when mine finally went into build as it stopped me messing with it !
That's the way to do it, definitely early signs of that terrible condition............ABSAlthough.... 👀
in the meantime I'll just leave this here...............I'm running out of things to change now....only viable option will be the GPU but that will require change to cooling and/or case.
Ditto. Can't wait until it goes into Build so I am forced to stop messing about with my order!
You are learning............if in doubt blame @Scott , @AgentCooper or @SpyderTracks , the rest of us are just bystanders............
