I replied to that more than once.Do you think i should go for the H80i if i plan to overclock?
yes, 1000w psu should be fine for sli
Do they do a leak test? Everyone says that you should do a 24h Leak Test when you have water cooling.
I would like to get it, i'm just not sure if its safe or not.
Do you think i should go with the h80i then or shall i just change for some good quality air cooler?
For me you can't beat Asus boards.Are you telling me that i should change from gigabyte to asus motherboard?
