Hmmm. Panda in Greek (πάντα) means "always". Are you saying I always take the last item in stock? [emoji848]
I never knew thatHmmm. Panda in Greek (πάντα) means "always". Are you saying I always take the last item in stock? [emoji848]
Belay that, I've just been messaged to say it's already dispatched. Depending on how the CPU versions end up playing out with Windows 11 I may have a TPM to sell come the Autumn...There's an Asus 14-1 TPM available on amazon.de now if you're quick, I've just cancelled my order. On closer reading of the Windows 11 requirements my i7-6700 is not supported, it's series 8 and above only. No Windows 11 for me then. Time to seriously think about Linux I think....
There are a few inconsistencies in that article.Bad news. Looks like Microsoft made a mistake earlier with guidance:
https://www.crn.com/news/applicatio...windows-11-tpm-requirement-is-for-version-2-0
"In the updated documentation, Microsoft has removed the reference to a “hard floor” for Windows 11 that would’ve allowed PCs with TPM 1.2 to still install the new OS.
Now, Microsoft says the compatibility requirement for Windows 11 is, in fact, a TPM 2.0 chip. “This article has been updated to correct the guidance around the TPM requirements for Windows 11,” Microsoft says on the documentation page.
TPM 2.0 was only released in 2019, suggesting that PCs made prior to that year may be incompatible with Windows 11."
I still expect this to be dropped, the backlash in certain quarters for this would hamper Windows 11 adoption, which Microsoft appears to think is important.
IRT to processors though, I would assume any processor that meets the minimum requirements should be fine, so I would say hardware from older Intel and AMD gens should be fine... if their boards support TPM 2.0.
All this is well and good (about TPM 2.0) but they way that Microsoft have engineered Windows 11 to only operate on TPM 2.0 enabled boards and with pretty recent CPUs, and then announced it overnight, is a massively dumb way to go about this.There are a few inconsistencies in that article.
I don't doubt that TPM 2.0 will be the hardfloor, that makes more sense.
But it wasn't released in 2019, it was released in 2014 and Microsoft made it a requirement for their partners to include it in all motherboards as of 2016.
Trusted Computing Group Releases TPM 2.0 Specification for Improved Platform and Device Security | Trusted Computing Group
Trusted Platform Module 2.0 Specification Provides Critical, Vendor Neutral Technology to Respond to Security Demands in Today’s Volatile Threat Landscape Portland, Ore., April 9, 2014 –The Trusted Computing Group (TCG) … Continue reading "Trusted Computing Group Releases TPM 2.0 Specification...trustedcomputinggroup.org
Trusted Plaform Module (TPM) 2.0
Provides guidance on what an OEM should know about TPM 2.0 and the features that require itdocs.microsoft.com
The 2019 reference may be when Intel made the library open source whereas before then it was proprietary to Intel and licensed as such, but even that was in 2018. The only reference to 2019 I can find is that that is the latest library version of TPM 2.0 Revision 01.59, but that's just applied by a firmware update, doesn't require new hardware.
TPM 2.0 Library | Trusted Computing Group
TCG has released the TPM 2.0 Library specification that provides updates to the previous published TPM main specifications. The changes and enhancements compared to the existing TPM 1.2 include: Support … Continue reading "TPM 2.0 Library"trustedcomputinggroup.org
I think that source has just scrubbed their info from Wikipedia which states the latest version of TPM 2.0 was released in 2019. It's poor reporting, they haven't done their groundwork.
Trusted Platform Module - Wikipedia
en.wikipedia.org
Which motherboard do you have?If, as you say @SpyderTracks, Microsoft made TPM 2.0 a requirement on all motherboards as of 2016 then why does my 2017 PCS build not have it?
Asus Z170-E. It has a TPM header but it won't support later CPUs (I don't think).Which motherboard do you have?
So that will work fine then. It’s just the CPU isn’t officially supported (whatever that means) as in the article I previously posted.Asus Z170-E. It has a TPM header but it won't support later CPUs (I don't think).
The CPU is the killer. But if Microsoft made TPM2.0 'a requirement' back in 2016 then it should already be on the board. It should already be on everyone's board.So that will work fine then. It’s just the CPU isn’t officially supported (whatever that means) as in the article I previously posted.
Features & details
Designed with 14-1 pin and SPI interface
Chip: Nuvoton NPCT750, compliant with TCG specification "2.0" Rev1.38
Common Criteria EAL4 + certified FIPS 140-2 certified CE and RoHS compliance
It depends on the board.I had to enable TPM in the BIOS settings but it's there, for anyone who wants to give it try see below
Basically enter BIOS go to Advanced settings. Click PCH-HW I believe was the option, then change the TPM setting from Hardware to Firmware and boom I now have TPM 2.0
Of course worth a nosy for anyone who might want to have a look thoughIt depends on the board.
Oh for sure! Thanks for the tip.Of course worth a nosy for anyone who might want to have a look though
I do believe that’s TPM 2.0You might be able to help here. I was under the impression that the TPM I've ordered was 1.2,but looking at the spec I'm not so sure..
Does that "TCG specification "2.0" Rev1.38" mean it's actually TPM2. 0? From my (not very clued up) research I think it is?
