So I wait 9 days for permission to flash my BIOS and it's likely to start causing more problems?Starting to think I'll just leave EXPO off and wait 6 months before considering a BIOS update, especially given my system is working fine
I tried disabling CPB to see if it was maybe a processor issue but same thing.It sounds like a memory issue to me. It's the sort of issues that you will get with unstable RAM.
It's already been noted that the latest BIOS updates can actually make stock RAM unstable when it requires more voltage than the stock settings allow. EXPO can rectify this but not until it's sorted out. It's a bit of a catch 22 situation so I would let PCS work it out.
My SoC doesn't even register as high as 1.1v! At least not on minimal use...I haven't checked it under load but I can't imagine it would shift that much
Was thinking that but if it is faulty then it's going back for RMA anyway and if it's not faulty it's still going back for RMA!You could always check that by removing the graphics card and plugging the monitor into the motherboard...the 7800x3D has integrated graphics(assuming you haven't disabled them in the BIOS of course)
Or, following Hanlon's razor, this was always the intention but in rushing to get it delivered, not all the ducks were neatly in their rows.So ASUS have removed the warranty bit on all the latest published Beta BIOS for their boards, seems the pressure is getting through to them.
So long as it's got XMP applied and not EXPO it should be fine.So one thing I did not check is the type of RAM installed.
It's listed as (2 x 16gb) 6000mhz CL 40-40-40-77
I checked and none of the Corsair AMD RAM has this spec. It seems this is Corsair RAM designed for Intel systems.
Would this cause the issues I'm seeing or does it not really matter?
I didn't see an XMP option. On the main page of the BIOS there is an EXPO drop with enable and disable options. Or is there advanced settings I should be checking?So long as it's got XMP applied and not EXPO it should be fine.
Thanks for the info, looks like we have the exact same RAM so if it's working on your AM5 board then it should work on mine. Looking more likely it's faulty RAM but will do the RMA and get it sorted.It is using EXPO..it's the same with mine. Corsair don't list my RAM at all (might be the same RAM as you), not even if I search for the model name...Crucial don't recognise it as Corsair RAM but HWInfo and CPU-Z both do.
It shouldn't be related to the issue you are having as mine has been stable with EXPO turned on and with EXPO turned off
Yeah a 4090 will eat up a 4k setting!I love my new system, RGB overload and all (was never a fan of RGB before...then I bought a system with RGB everything lol). I was gaming on a Series X console on a 4k TV and wanted to play games using the full 120Hz of my TV (as no games on the Series X currently allow that) and my system has not disappointed....unsurprising given it's got a 4090 in it.
RAM is silicon, hence your bound by the same silicon lottery as if you were overclocking a CPU.It is using EXPO..it's the same with mine. Corsair don't list my RAM at all (might be the same RAM as you), not even if I search for the model name...Crucial don't recognise it as Corsair RAM but HWInfo and CPU-Z both do.
So on my BIOS (when I got the system) it had EXPO Enabled on the main page. In the advanced settings under the AI Tweaker it was set to "Auto" which I assume knows the capability of your RAM and sets to either EXPO or XMP.RAM is silicon, hence your bound by the same silicon lottery as if you were overclocking a CPU.
One DIMM will have entirely different voltage capabilities to another, and a difference of 10mV from an EXPO pre applied OC to an Intel XMP could mean the difference between stability and BSODs. This is exactly why it's so important to buy matched pairs, because they're likely from the same wafer and therefor have similar electical properties.
Saying "it works fine on mine" is a bit like saying take my glasses, I can see fine so you should be able to.
The Intel RAM DIMMS do not have any EXPO profiles loaded on the DIMM itself, so it's not tying in correctly with the OC profiles on the Mobo.
EXPO DIMMS will normally have a few XMP profiles loaded additionally to the EXPO ones.
I would still suggest using XMP if you don't have EXPO RAM as the voltage parameters are designed for that DIMM.
You're right, if you're still getting instability with EXPO off then it's nothing to do with either XMP or EXPO.So on my BIOS (when I got the system) it had EXPO Enabled on the main page. In the advanced settings under the AI Tweaker it was set to "Auto" which I assume knows the capability of your RAM and sets to either EXPO or XMP.
Odd thing is the timings on my RAM (checking in Task Manager) were around 5800 and not 6000.
After disabling EXPO (again, just on the main BIOS page as it's worded that way) the RAM clocked down to 4800 and still had issues.
I would run a Memtest86 run on both DIMMS from a bootable USB
Can you upload a screenshot of your optional updates page?
Oh, I thought that was with EXPO on, didn't realise it was affecting him with it off.This is the weird behaviour that Jayz2cents had. With EXPO and XMP off, the system would BSOD as the stock settings weren't feeding the RAM enough voltage. Ended up in that rock and hard place scenario where with EXPO off, it wouldn't post. But with it on, it would... but lose warranty.
