TheWaryFiend
As you advised, flash drive and the rest of it.
Can you say the steps you went through?As you advised, flash drive and the rest of it.
Hiya, so then you want to run windows update repetitively until there are none left.Hey Spyder,
I followed step 1 in the below:
How to do a Clean Install of Windows 10 the Easy Way
The Windows 10 upgrade process drags old files, settings, and programs from your previous Windows system to your new one.www.howtogeek.com
I did it all as detailed above.
And you'll need the wifi driver from here as wellThat wifi card has the wrong drivers applied by windows update, so you need to manually update it from here:
