Help with motherboard and Med Med High Spec
Littlesackninja
Samsung SSD's, Case's, And HDD's.
Backround info: The case i intend to get is the ZALMAN Z11 PLUS BLACK MID TOWER CASE, I intend to use 1 Samsung 120gb 840 EVO SSD aswell as 1 1tb Caviar black,
Question 1: Is black caviar drive faster than the green drive.
Question 2: Does the SSD fit in the case as the SSD is a 2.5" Drive and the case says that it only has 4 x 5.25" Bays And 6 x 3.5" HDD/SSD Bays, as when i proceed nothing comes up, Will it use a adapter to scale it up?
Question 3: Is the zalman Z11 plus a good case?
T
TheGeeza
1. Yes the caviar black is faster.
2.The case should come with an adapter for the ssd which pcs will use when building.
3. Not sure. Have a look at online reviews or wait for a user who has the case to comment.
Wozza63
Biblical Poster
Q1 - Yes, considerably faster
Q2 - Yes, a bracket will be used with the SSD to secure it to a 3.5" bay
Q3 - Yes, its a good case but if you are intending on demanding gaming or using demanding software you may want to get a better case
Q4 - The 1600MHz RAM is more than enough for speed, but you may want to get 8GB depending on your budget.
Would you be able to provide us with your current chosen spec, budget and intended use so that the best components can be chosen.
Littlesackninja
AMD FX-6300 Six Core CPU (3.50GHz/8MB CACHE/AM3+)
Gigabyte 990XA-UD3 AM3+ (ATX, DDR3, USB 3.0, 6Gb/s)
4GB KINGSTON DUAL-DDR3 1600MHz (1 x 4GB)
2GB NVIDIA GEFORCE GTX 770 - 2 DVI, HDMI, DP - 3D Vision Ready
Free Item
Free Item
FREE WATCH DOGS with GTX 660 & 7 Series GPUs!
1st Hard Disk
120GB Samsung 840 EVO SSD, SATA 6Gb/s (upto 540MB/sR | 410MB/sW)
CORSAIR 850W RM SERIES™ MODULAR 80 PLUS® GOLD, ULTRA QUIET (£99)
CoolerMaster Hyper 212 EVO (120mm) Fan CPU Cooler (£29)
Littlesackninja
I am still deciding over wheather i should get the FX-6300 Or the 6350 or 8320, if i go for the 8320 then i have to step up the psu to 1000w as i wil get a second GTX 770 in the future, can you shed some light on this?
T
TheGeeza
Free Item
Free Item
1st Hard Disk
What is your budget?
You could do better if the rig is for gaming. Upgrade the warranty for £5.
Littlesackninja
That case is about as much as i can afford. but if required i could possibley stretch it out to somthing like the NZXT PHANTOM 410 WHITE GAMING CASE but i would rather upgrade cpu or the specs instead
Littlesackninja
Also the different cases say what they are designed for, Does this actually matter as the Zalman says its for mid level gaming, does this differ it from something like the NZXT Phantom or PCS Defender which say they are extreme gaming cases. I chose the zalman because it has space for many drives, and it has a dust filter, aswell as it looks AWESOME, is there any downsides to it though?
T
TheGeeza
Generally, the extreme gaming cases will have more space and better airflow.
Rakk
The Awesome
Littlesackninja I've merged your threads together, its easier if you keep to one thread when discussing the same machine, means people don't ask the same questions more than once.
Littlesackninja
Ok i have a question, Should i get the FX-8320 And the Gtx 770 (Sli later), OR the FX-6300/6350 with the 770 (Sli later)
If the FX-63XX which one should i go for? (6300 or 6350)
I will be doing high end gaming and maybe a few minor apps on a second screen (Chrome ect)
Which Processor will give the best framerates for stuff like Crysis 3?
Littlesackninja
Can you post a exclusive link of a build at £880, Or can you suggest a few good i5 or i7 Processors around that mark (with a Geforce gtx 770)
InWIN GT1 BLACK GAMING CASE
Intel® Core™i5 Quad Core Processor i5-4690 (3.5GHz) 6MB Cache
Gigabyte Z97-HD3: ATX, LG1150, USB 3.0, SATA 6GBs
8GB KINGSTON DUAL-DDR3 1600MHz (1 x 8GB)
Free Item
1st Hard Disk
CORSAIR 650W VS SERIES™ VS-650 POWER SUPPLY
Price: £878.00 including VAT and delivery.
Unique URL to re-configure: http://www.pcspecialist.co.uk/quotes/intel-haswell-pc/3ULavNupyZ/
Littlesackninja
When i order i pc, will it come with all the spare things, Eg spare power cables from psu, screws from the case. Is there a way i can specify this?
steaky360
Your rig will be supplied with any spares that it would normally come with, any PSU cables that come with your PSU which are not used will be supplied for example) You won't get random spares that would not normally be supplied however.
