Help with motherboard and Med Med High Spec
T
TheGeeza
If you follow the config link that keynes posted then you can tweak it to how you like. When you press proceed the configurator will tell you if the case you want is not suitable.
T
TheGeeza
Also will i need any thermal materials (thermal paste) or such?
With your PC?
No they will put the PC together completely in working order unless you tell them otherwise.
Any thermal interface materials will be installed already.
I just want to put the specs you posted in a synthetic benchmarker, Im probably going to get it but i just kinds want to see it.
I have no clue what a synthetic benchmark is. If you want to check gaming performance just google reviews for the graphics card you are choosing.
A314159
Super Star
Actually crossfire supports 2 different cards. I would still get the i5, because single core performance on the 6300 is pretty meh, but yeah....
Rakk
The Awesome
True but only specific AMD cards can be paired with specific other cards, so in general it's just simpler to say they need to be the same :)
For the OP's budget I'd stick with the AMD, otherwise compromises on other bits and pieces may be required.
T
TheGeeza
Depends on the power draw of your cards.
I managed to run 2 770s on my old 850w psu. It was platinum though.
Littlesackninja
With only 1 770 will it be enough? I will actually be usuing a sshd not hdd and a Super Quiet 22dBA Cooler instead of the default cooler
T
TheGeeza
Will 850w be enough for your system with 1 770?
Yes it would be more than enough.
Were you planning on sli soon? It's better to go a single more powerful card if you wanted more power remember.
Littlesackninja
The 770 is currently the only card i can really afford all the other cards are too expensive so once i have got more money after i bu it il get a second card
