Littlesackninja
Hi, I have a few questions regarding building a pc from this website.
The pc i intend to build is in the £750 mark and should run medium-high end games on medium and high settings.
Question 1.0:
Im contemplating buying a pc ( https://www.pcspecialist.co.uk/computers/intel-haswell-pc/ ) Is this spec good and will any problems arise like two low power or to small case?
PCS ALPHA TRION 7622B BLACK CASE
Intel® Core™ i5-4590
Gigabyte Z97-HD3
8GB HYPER-X BEAST 2133MHz
GPU
2GB AMD RADEON™ R9 270X
1TB 3.5" SEAGATE HYBRID DRIVE
24x DUAL LAYER DVD WRITER
Corsair 650w vs series bs-650
CoolerMaster Hyper 212 EVO
ONBOARD 6 CHANNEL (5.1)
Wireless 802 11n 300mbps pci card
2 x USB 3.0 PORTS & 4 x USB 2.0 PORTS
Question 1.1:
Do i need the coolerMaster Hyper 212 EVO Or can i use the Super Quiet 22dBA Cooler?
Question 1.2:
Is the motherboard that i chose a powerful one? I read up on it and all i found was it is "Ultra durable" This is fine but is its performance good?
Question 1.3:
Do i need the Wireless 802 11n 300mbps pci card to have wireless connection and can it do lan aswell (and lan through plugs) or can i just use the one above it (10/100/1000 Gigabit lan port thing? Does the gigatbit thing do wireless?
Question 1.4:
Do i need the gpu and will it help or just make it hotter and stuff?
Question 1.5:
Will the 650w power supply be enough?
Question 1.6:
Is there a way i can have build in sound?
Question 1.7:
Is the hybrid drive i chose a fast drive?
Question 1.8:
Will any problems arise?
Question 1.9:
Is it a powerful setup?
Question 2.0:
Are the ram cards (8GB HYPER-X BEAST 2133MHz) Fast cards?
Question 2.1:
Will it fit in the case?
Sorry for the many questions but i just want to be sure when i buy it.
Appreciate the help in advance
(The machine is supposed to be a medium-high end spec machine)
Question 1.0:
Gigabyte Z97-HD3
GPU
Question 1.1:
Question 1.2:
Question 1.3:
Question 1.4:
Question 1.5:
Question 1.6:
Question 1.7:
Question 1.8:
Question 1.9:
Question 2.0:
Question 2.1:
