FPS drops by ***90***% for brief moments
  • Thread starter Deleted member 94250
  • Start date
I'll be getting 73-80 fps in RDR2 online, but whenever another player approaches or I fire a weapon the FPS tanks. and it tanks HARD. Down to 24fps, Friggin 8 FPS, and the screen freezes for one second, then it gows back to normal only for it to repeat. THis started right now. When i was playing in the morning fps only dropped to 40-50 but it was smooth, now this stuttering(?) is getting extreme.
Please help!
Quite a list of medical problems with this laptop but this last one is frustrating as al hell.
Please help!
Have you checked your server connection? What's the latency?
Just need to google the game servers. There will be a setting in the game menu somewhere.
dude. this stuttering is still going on in the game, but also started in CHROME and MS WORD of all apps. please help
What are your full specs from the order page?
one sec:-
Showing Order Reference no XXXXXXX
Promotional DiscountSpecial Offer - Save Now On Intel Core i7/i9 Powered Laptops - Offer Ends 2nd December 2019!
Chassis & DisplayOptimus Series: 15.6" Matte Full HD 120Hz 45% NTSC LED Widescreen (1920x1080)
Change to: Optimus Series: 15.6" Matte Full HD 60Hz 72% NTSC LED Widescreen (1920x1080)
Processor (CPU)Intel® Core™ i7 Six Core Processor 9750H (2.6GHz, 4.5GHz Turbo)
Memory (RAM)16GB Corsair 2133MHz SODIMM DDR4 (1 x 16GB)
Change to: 16GB Corsair 2666MHz SODIMM DDR4 (2 x 8GB)
Graphics CardNVIDIA® GeForce® GTX 1660 Ti - 6.0GB GDDR6 Video RAM - DirectX® 12.1
Change to: NVIDIA® GeForce® RTX 2060 - 6.0GB GDDR6 Video RAM - DirectX® 12.1
1st Storage Drive256GB PCS 2.5" SSD, SATA 6 Gb (550MB/R, 420MB/W)
Change to: NOT REQUIRED
1st M.2 SSD DriveNONE
Change to: 512GB ADATA SX6000 Pro PCIe M.2 2280 (2100 MB/R, 1500 MB/W)
Memory Card ReaderIntegrated 6 in 1 Card Reader (SD /Mini SD/ SDHC / SDXC / MMC / RSMMC)
AC Adaptor1 x 120W AC Adaptor
Change to: 1 x 180W AC Adaptor
Power Cable1 x 1 Metre Cloverleaf European Power Cable
Change to: 2 x 1 Metre Cloverleaf UK Power Cable
BatteryOptimus X Series 4 Cell Lithium Ion Battery
Change to: ARCTIC MX-4 EXTREME THERMAL CONDUCTIVITY COMPOUND
Sound Card2 Channel High Def. Audio + SoundBlaster™ Cinema
Bluetooth & WirelessGIGABIT LAN & WIRELESS INTEL® Wi-Fi 6 AX200 (2.4 Gbps) + BT 5.0
USB/Thunderbolt Options1 x USB 3.1 PORT (Type C) + 2 x USB 3.0 PORTS + 1 x USB 2.0 PORT
Keyboard LanguageMULTI COLOUR BACKLIT UK KEYBOARD
Office SoftwareFREE 30 Day Trial of Microsoft® Office® 365 (Operating System Required)
BrowserGoogle Chrome™
Change to: 3 Year Silver Warranty (1 Year Collect & Return, 1 Year Parts, 3 Year Labour)
Dead Pixel GuaranteeNONE
Change to: 1 Year Dead Pixel Guarantee Inc. Labour & Carriage Costs
Build TimeStandard Build - Approximately 4 to 6 working days
Promotional ItemFREE Red Dead Redemption 2 & More! w/ select Intel i7 & i9 CPUs!
In addition to the advice from SpyderTracks re your temps, I see that you have a 512GB SSD as the sole drive. How full is that drive?
In addition, are you using a WiFi connection to your router or a cable connection? If you're using WiFi then try a temporary cable connection to eliminate WiFi as the cause (which it could well be).
Who else in your home is using the same router as you at the same time? What download speeds do you get?
There are so many things that could cause these lags, it's a process of elimination really. Since it's a laptop then SpyderTracks suggestion of checking your temps under Prime95 loads is a good place to start.
150gb free.
did restart the wifi connection and used a LAN connection, but it didn't help. still lagging.
only one other person uses the same wifi.
this is the test i'm doing, anything to change?
edit to clarify: the lag in the game may be an internet thing but being unresponsive in chrome is like, wtf, my budget laptop works better than this
150gb free.
View attachment 15827this is the test i'm doing, anything to change?
OK, it's none of those causes then. I would run that Prime95 as is with the defaults. Keep a close eye on your temperatures though.
chrome and prime 95 running at the same time, also its really, really unresposnive right now. takes half second to type a letter occasionally
edit:
stopeed the test after a while and this is the idle temps
