NoddyPirate
Grand Master
I think with my board the 5600X just sits so far below the capability of the VRM that it just isn't a problem. Also, the relatively low number of phases it's putting out probably keeps the temperatures down too. But a 10900K would worry me!! At the same time, your average VRM can handle an awful lot of heat. I was watching a GN video recently where they were doing a crazy OC to get the their VRM on a cheap board up towards 120 degrees C. Not recommended obviously, but it happily carried on!I’m sure i saw a Linus video, where he used a prime Z490 with a 10900K or something and it was fine. I assume the VRM’s on that are somewhat similar
I was playing with the VRM phase control the other day - via the DIGI+ VRM thing that ASUS have on their more basic boards. Upping the phase switching frequency seemed to give a slightly smaller spread of voltages to the CPU cores - which is as you'd expect - and would be better for more critical OC's too - but would also have upped the VRM temperature in the process. It'll be another days work to figure out how much of a temp hike it actually creates.
High spec boards have big heatsinks not just to handle high power CPU's but also to be able to deal with their own high phase count and high switching frequency - to create that better quality power supply they give you. But I think these days, even lower spec boards are probably being better equipped to deal with temperatures than in the past. I certainly seem to only have memories of chipset heatsinks a decade or two ago, but otherwise exposed VRM components - even if I didn't actually know what they were at the time....!
