NoddyPirate
Grand Master
As a newbie to custon builds, I found figuring out what fan config I might need more than a bit confusing. In particular I was convinced that I should add exhuast fans while I had the chance. Guidance here in the forum was great as always - but in the end I basically over-specced my build with fans given the cost was so cheap. I think I was influenced too by my previous Lenovo mini tower cooking itself slowly under anything more than idle load.
I have a Corsair 220T with it's three SP120's on the front, then I have two basic PCS fans as exhausts in the roof and an Artic PWM 120mm fan as rear exhaust. Plus the PCS Frostflow 100 RGB on the CPU.
My CPU is the Ryzen 5 5600X - about which I had read more than a few reports of high temperatures with the stock Wraith Stealth cooler.
I was really bored today so thought I would play around with the fans and see what difference they all actually make to the CPU temperatures with my particular setup. Everything is stock and no overclocking on anything. If the following is useful to anyone else - great - if not, the whole experience helped me pass the time this afternoon - so no loss!
I ran Cinebench R23 on a multi-core loop to have all cores at 100% use for about 15 minutes to warm everything up. To test a setup I run a config for about 5 minutes before taking a 1 minute average. The GPU was not under load at all - bear in mind that a big power hungry GPU pumping hot air into the case will obviously make everything warm up quite considerably.
The CPU Cooler was first up for some abuse.
CPU Package Temp - PCS FROSTFLOW 100 only - all other fans off.
83 Deg C - 350 RPM (Minimum Speed)
77 Deg C - 750 RPM (Upper limit of what I would call silent)
72 Deg C - 1,000 RPM
68 Deg C - 1,500 RPM
61 Deg C - 1,900 RPM (Full Speed)
I personally think these are super results given no case fans were running at all. Above 750 RPM or so the rear exhaust fan was turning slowly from the breeze the CPU fan was creating - and it reached 200 RPM when the CPU fan was a full speed - showing that plenty of air was moving through the heatsink. CPU clock speeds maintained steady at 4.3 GHz, but at temperatures above 70 degrees it reduced slowly to 4.0 GHz at 83 degrees.
I then played with adding the other fans to see which gave the most benefit. For a more useful results all speeds for the following were set to around 950-1,000 RPM - giving an audible but still very quiet system.
72 Deg - CPU Fan only
68 Deg - CPU plus Rear Extract
68 Deg - CPU plus Roof Extract (2 fans)
65 Deg - CPU plus Rear & Roof Extract (2 fans)
66 Deg - CPU plus Front Top Intake only
63 Deg - CPU Plus All Front Intakes only
62 Deg - All fans running.
Interesting that a single intake fan at the front is bascially as useful as my three exhausts. Fresh air is king! Also with just exhausts, air was being sucked in from every available place, filtered or not - not great for dust!
With just the three front intakes and the CPU fan on it's own - basically the stock 220T case and a tower CPU cooler - temps were great. The exhaust fans added very little extra to the mix.
In summary - all the above is totally subjective and specific only to me and my system - but it does show that a decent number of fans allows you to run the same temperatures with a much quieter system - which was my initial goal really. More really is more. All my fans running quietly at or below 1,000 RPM is just as good as having only the CPU Fan running at full speed. That also shows that the case is allowing plenty of air in and out too.
But - if I had left the exhaust fans out of the mix, I would only see a degree or two difference overall. If I had a big GPU dumping heat inside the case then I would imagine exhaust fans would be much more useful - but forcing fresh air in will always give more benefit overall I would think. For the €11 the two PCS fans cost me, and the €7 I paid for the Arctic one on Amazon, I'm happy I got them all the same.
FWIW - with all fans at full speed the CPU got down to 57 degrees under full load. Not that great a difference from the 1,000 RPM results given it sounded like Noddys car after the Goblins has taken it for a run through the dark forest......
So for me - I say the 220T is a great case and seems to be plenty capable of moving air in and out. The PCS Frostflow 100 cooler also seems to be plenty good enough for me and could easily handle my personal workload all on it's own if it had to - albeit it rather noisily!
G'night all!
G'night all!
