I requested an rma for the 3rd time. Pcs installed all drivers invluding ones I had no use for eg nvidia wen I have 7970m amd
Seems like you're complaining about software more than anything else, so why not try a fresh install of Windows then install every single driver yourself?
I still can't believe Windows 8 displays a giant sad face when it crashes. Joke of an OS (and yes I've used it extensively).
My advice would be to do a fresh install of Windows 7 instead. If its a driver issue chances are that the drivers will be a lot more mature for W7, but don't quote me on that as I have no idea what changes were made at system level from W7 to W8. The drivers usually come bundled with all supported versions anyway to reduce the risk of downloading the wrong ones.
I'd also avoid using the normal drivers for AMD, as they are notoriously bad for CrossfireX. Get the beta 12.11 drivers from here: http://support.amd.com/us/kbarticles/Pages/AMDCatalyst1211betadriver.aspx
I've never had the sad face on my Windows 8.
Me neither, although I haven't had a major crash yet touch wood.
