Yes,uninstall all AMD software.do I uninstall catalyst control center aswell
Yes.and reinstall fresh now ive done all that?
If you have done a fresh install of the driver,you shouldn't really need to do anything else except maybe enable crossfire.ive done that what should I do next
Hmm,sorry not sure about that,see how it goes as it stands.it pre enables it should I enable the thing underneath about using xfire for applications that have no associated application profile
See how it goes,without making anymore settings yet.that's ok
It's normal for a lot of errors to appear in the event viewer,It could still be a software problem,but I'm sure PCS will sort it out for you whatever the issue.Let us know how you get on.thank you. I requested an rma for tomorrow and because of his it shows how many problems ive had it says ive had 21 critical errors in the past 7 days so I hope pcs can fix this when they receive it.
