Wifi is super slow on my PC
Hibbs
If that’s sorted by CPU then it proves there’s an unlisted process that’s working away on your cpu and likely your network stealing resources, probably a crypto virus.
If I were you, I’d uninstall Norton because it’s rubbish, use windows defender, then I’d install malwarebytes free and do a full system scan including root kits.
Hibbs
I just downloaded malwarebytes and did a scan and nothing came up
is that the right scam to do????
Hibbs
I though I was not being rude to be fair, but I see that it come off in the wrong way, but I didn’t mean it to be rude.
Deleted member 17413
You could try a reset, or possibly even a fresh install (which is more likely to resolve it as its a complete fresh slate) but I would wait and see what the mods say and go through step by step like you have been.
If you find yourself online as the same time as Spyder it would make things easier to go through, but troubleshooting is a step by step process and a reinstall would be a final solution type thing if you cant iron out the issues.
How does it? I'm not seeing that proof? Curious?
Absolutely agree with this and I'd bet that Norton is the cause of the slow WiFi. It's junk, get rid of it.
Macco26
Expert
By no means I am as dedicated as the people who are helping you here, but by any means can you check from the Control Panel, Wifi adapter Status which Connection speed your Wifi card has handshaked with your AP/router?
Example, here is 433 Mbps on my end:
Hibbs
Hi, I have download that other security software(Malwarebytes) and I have done a multiple normal scans and nothing has come up for me, but I don't if it has included the root kit as I just did multiple scans.
Hibbs
I went on to my Laptop and got a screenshot of what it says with my internet
Hibbs
This is what came up what I did the same thing on my PC
