Ive bought the Windows 10 pro key from online, put it on their computer but it didnt work because the key only works for windows 10 pro and their windows 10 refused to accept because its wrong windows 10 version, so i had to find a temporary key for windows 10, chuck it in it accepted, it gave me uption to upgrade to windows 10 pro, i hit accept once thats done i've placed my windows 10 pro key and it accepted aswell.
Yes the pre build computer had windows 10 test fase and to activate i had to put a windows 10 key, but the windows 10 pro key i had dint work since it was the wrong windows key. Only worked once ive upgraded to windows 10. Still waiting on a call. its 9 PM in UK time atm im guessing they will call around 1 or 2 in afternoon like last time. Wich i dont understand is it was fixed for a week or 2.... They told me to uninstall all USB drives, audio drives and reinstall them using the link they provided, after i done that i had no more freezes but 1 or 2 mouse crashes. Since i started playing Watch dogs 2, Using OBS about a week ago it started again all the USB crashes. Everytime i try to uninstall USB drives wich has like 20ish or so...after i un install 1 of them mouse/keyboard is shut off so i cant delete the rest.
USB list -
ASMedia USB root Hub
ASMedia USB3.0 eXtensible Host Contoller
ASMedia USB3.1 eXtensible Host Contoller
Corsair Hydro Series 7289 USB device
Generic Superspeed USB hub
Generic USB hub 6 times
Inter(R) C610 series/x99 chipset usb enchanced host controller #2 - 8D2D
Inter(R) C610 series/x99 chipset usb enchanced host controller #1 - 8D26
Intel (R) Usb 3.0 eXtensible host controller - 1.0 (Microsoft)
USB Composite Device 3 times
USB Mass Storage Device
USB root hub 2 times
USB root hub ( USB 3.0 )
And for Human Interface
HID-Compliant Consuer Control Device 3 times
HID-Compliant device 2 times
Hid-compliant headset
Hid compliant system controller
HID compliant vendor-defined device 4 times
Razer Naga Chrome 3 times
USb input device 5 times.
Ok, so you have a valid Windows 10 pro key and license, that good.
The way you 'upgraded' to Windows 10 Pro isn't so good though. To go from Windows 10 Home to Windows 10 Pro you really should have done a completely clean install. I realise that Windows allows you to upgrade in place but it's well known that this often causes all sorts of problems, not unlike the ones you're having.
I'm sorry to keep beating this drum, but your only reliable way forward now is to get a good copy of the Windows 10 Pro install media on a bootable USB stick or DVD drive and clean install that. If you can't download that then ask a friend to do it for you.
Once you have that media in your hand come back on here and I (or others) will give you step by step instructions on how to clean install Windows 10 pro from that media.
I know you have convinced yourself that you have a hardware issue, and that's not impossible of course, but until you have a good clean copy of Windows installed you cannot be certain.
