ExpiredBreadlet
Yep, that workedI think that is your problem.
SATA ports 5/6 are disabled when socket 2 is used for m.2 drives. I'm not sure if the top or bottom socket is labelled as no.2, but I would suggest putting the m.2 drive in the higher socket and see if you have the same issue. I would've suggested plugging the SSD in sata 1 through 4 if they are available as that would have been the easier way to test.
Edit: just found online manual for your board and even more convinced that is the issue. If you check page 10 it confirms SATA ports 5/6 are disabled when lower m.2 socket is used
Connectors With Shared Bandwidth - Asus ROG STRIX B550-F GAMING (WI-FI) Manual [Page 10]
Asus ROG STRIX B550-F GAMING (WI-FI) Manual Online: Connectors With Shared Bandwidth. FLBK_LED1 U2_56U32G1_78 U32G2_C6 U32G2_5 LAN_U32G1_34 HDMI _DP AUDIO A A A A Configuration PCIEX16_2 PCIEX1_1 A PCIEX1_2 PCIEX1_3 Configuration M.2_2 B SATA6G_56 • • x BIOS_FLBK EATX12V_2 EATX12V_1...www.manualslib.com
Many thanks to you all 😁
