sck451
It looks really good, but honestly I'd make a few tweaks. First off, I wouldn't add any extra fans. If it turns out to need extra fans, they're easy to add, but I really doubt you will with those components. Neither 5600X nor 3060 Ti are super-hot. Then I'd change the motherboard to a B550 one (in some ways it's better than the Tuf X570 despite theoretically being a lower tier), put the PSU down to 850W (the 1000W is no longer such a good deal for some reason), and splurge a bit more on a better SSD configuration. Overall these changes end up saving you £30.
Finally, I wouldn't worry about rear ventilation: it'll be just fine. Partly because the heat won't be that significant, and partly because air can always escape through the top of the case as well.
ASUS® TUF GAMING B550-PLUS WiFi (DDR4, USB 3.2, 6Gb/s) - ARGB Ready!
CoolerMaster Hyper 212 (120mm) Fan CPU Cooler Black Edition
Standard Build - Approximately 14 to 17 working days
Price: £1,645.00 including VAT and Delivery
Unique URL to re-configure: https://www.pcspecialist.co.uk/saved-configurations/amd-am4-gen3-pc/UXnGQNhKBr/
