Random bluescreen, then boot issues, then won't boot?
sounds as though is trying to boot a network drive, go into the bios and check the boot order, the boot manager should be at the top, take a photo and post it here, so we can see what it's seeing
averagepcuser
USB Arriving today. Will get Windows Creation Tool or whats it called and use it tomorrow. Will keep you posted
gary2112
First thing I would do is check your system temps https://www.cpuid.com/softwares/cpu-z.html
with this app write them down .it it crashes in this test then you might need to replace your thermal paste .then repeat checking your CPU and GPU temps next if this fails see if there is a bios update for your motherboard and also check to see if there is driver for chipset also I noticed PSU CORSAIR 550W CV SERIES™ CV-550 POWER SUPPLY seems a little low for your system does your system crash under heavy load IE playing games
averagepcuser
no. max power i need is actually 376v. and I can't access the PC only bios it doesnt boot as far as even entering the pin. however, tomorrow a new SSD is arriving PCS shipped me. i'm getting an 8gb USB to download microsoft creation tool and then when the SSD comes slot it in and etc.
gary2112
And as for you fast boot problem all you need to do remove the side your case some motherboards have button to reset the bios other don't if it the later then all you need to do is unplug the pc from the power supply make sure you touch the case before you touch anything inside your pc get a small flat headed screwdriver find the motherboard battery small and silver looking and there is clip just gently remove the battery from the motherboard using the clip and remove the battery leave the battery out for 5 minits and then just click the battery back in your bios will now be reset
averagepcuser
yes i did do that, check the thread btw if you haven't
averagepcuser
only take it out for 40 seconds is needed
There's nothing wrong with the BIOS, it's already been established its a failed drive.
The OP has already established with PCS that the SSD is dead. Until PCS swap the SSD no further troubleshooting is either needed nor wise.
