The reason for that is you're seeing the CPU cycles that were used to start Task Manager. The CPU drops later because its now started and using much less CPU.No problem thank you. The CPU still seems to be at 50% when I go on to task manager then drops down to 2%, there are no updates currently going on so is this something I should be looking in to or disabling?
