Poor Wifi Speeds
MrHolmes
Taken delivery of my new Optimus Pro XI last week and I'm having a massive issue with the wifi, my other two laptops gave the same speed when wired as they do on the wifi but this PRO XI gets appauling speeds. Currently downloading from steam at 382.9 kbps, normally this should be around >4.0MBs (comparing my other laptop), having reset the router, changed it. tried all channels on 2.4/5ghz nothing has worked.
Can you post your full specs from the order page?
raypat
To confirm this download speed is universal across other platforms, downloading from dropbox and other sources are poor speeds, not just steam?
MrHolmes
Steam, battle.net, any download performed, even surfing the net is slow and sometimes unrepsonsive, pressing f5 an awful lot when pages do not repsond. This does NOT occur on any other device in the house, phones, tv streaming, other laptops etc. Just this Pro XI
MrHolmes
Sorry missed your post first time round:
Chassis & DisplayOptimus Series: 17.3" Matte Full HD 144Hz 72% NTSC LED Widescreen (1920x1080)
Processor (CPU)Intel® Core™ i7 Six Core Processor 10750H (2.6GHz, 5GHz Turbo)
Memory (RAM)16GB Corsair 2666MHz SODIMM DDR4 (2 x 8GB)
Graphics CardNVIDIA® GeForce® RTX 2060 - 6.0GB GDDR6 Video RAM - DirectX® 12.1
1st Storage Drive1TB Samsung 860 QVO 2.5" SSD, SATA 6Gb/s (upto 550MB/sR | 520MB/sW)
1st M.2 SSD Drive128GB ADATA SX6000 LITE M.2 2280 (1800 MB/R, 1200 MB/W)
Memory Card ReaderIntegrated 3 in 1 Card Reader (Full Size SD / SDHC / SDXC)
AC Adaptor1 x 180W AC Adaptor
Power Cable1 x 1 Metre Cloverleaf UK Power Cable
BatteryOptimus Series 46WH Lithium Ion Battery
Change to: ARCTIC MX-4 EXTREME THERMAL CONDUCTIVITY COMPOUND
Sound Card2 Channel High Def. Audio + THX Spatial Audio
Bluetooth & WirelessGIGABIT LAN & WIRELESS INTEL® Wi-Fi 6 AX201 (2.4 Gbps) + BT 5.0
MrHolmes
First pic is current download speed on Steam, 2nd pic is what i'm seeing every time I try to load a page.
Wifi speed test - https://www.speedtest.net/result/9389801089
Wired Speed test - https://www.speedtest.net/result/9389816964
2nd laptop
Wifi test - https://www.speedtest.net/result/9389834048
Im 8feet away from my router, there is no electrical interference between my laptop and the router, the tests above are ran on the same channels one after the other. Both laptops have been tested on both 2.4ghz and 5ghz, consistently the Pro XI is miles behind.
2nd laptop
When you reinstalled windows how did you install drivers? Where did you source them?
MrHolmes
Updated through device manager for the latest drivers, this has made it worse.
I cannot permanently plug into the router no. For testing yes but permanently not a chance, not with 2 small wire loving children in the house :p
I am RMA'ing the laptop anyway due to the fan issue, this is just another thing thats making me rethink my choices and wondered if I could fix it all myself and not have to go through that process.
I just meant for testing, not permanently.
If you go into device manager, delete the current wireless device and reboot. That will install the latest one, if not, youlll need to plug into the router and run windows update.
MrHolmes
Done that, its literally made it worse. After a few BSOD, finally rebooted, updated all drivers through windows. Im going to take it as this Wifi card is very poor. Thanks for trying to help.
There's an issue that needs fixing. It's not the fact that that's just how it works, there's something wrong that needs addressing.
But yeah, if you've got an RMA then might as well get PCS to troubleshoot.
Windows installed - although I've had to reinstall as per PCS instructions to solve the fan problem.
Was that a clean install via bootable media deleting all existing partitions? If not then I would advise that you do that, it's the only reliable way to ensure that you have a fully clean system.
That you're getting BSODs strongly suggests that you don't have a clean system. Before RMAing any computer it's wise to clean install Windows to ensure it's not a software problem.
MrHolmes
Will try that, I cant even play anything online now as its just constantly disconnecting. Going to try the "clean" install.
MrHolmes
Full clean install has done nothing. All the bugs I've mentioned, WiFi, fans, headphone socket (difference convo), are still present. I think I'll be requesting a refund.
