I do sometimes wonder if people understand what they’re buying when they choose a custom PC or laptop. It’s by no means the same experience of buying off the shelf, you’re supposed to know basic windows and driver administration. You will have to do this kind of thing a lot, you’ll also have to maintain the hardware with regular clean outs and repastes. It is quite common for the initial windows setup to fail. It’s a Microsoft issue, not a PCS issue.After serveral reboots and making sure all updates via windows updates have been installed, WiFi appears normal. Shouldnt have taken all this messing around to get normal WiFi speeds though.
This has been raised with them. It’s a brand new chassis and they’re investigating with the manufacturer. BIOS fan profiles are often not correct on first iterations for a new chassis.Fans are still an issues, they dont change unless "fan boost" is applied, no gaming laptop I've ever come across has such poor functionality that you cant adjust the fans. Their excuse that the cooling is sufficient enough and its operating as normal I just dont buy. I would like not to be sat with a small cooker on my lap or at my table or feel like I need to turn on the jet engine just to cool it down.
