I dont like waterxooling, i go with the original, water and electronics do not mix, and this is why i go with air, if it was completely copper pipes then i might consider this, it will be much more reliable and less likely to burst, i will be keeping with my titan thank you
just looked a little further into that fishtank pc and the person who owns it has kept it running solid for 3 years!!!!
plonker why didnt he just use a fishtank? i bet he used perspex and it couldnt hold the pressure of the oil inside.
Yeah but since you don't know what he was using as a case, you have no idea whether he bodged it together or not .i dont think it was that harsh if you had a massive container of oil on your desk would you hold it in something you bodged together
Yeah I remember reading about another person who did a similar thing like this in CustomPC mag, the problematic part was stopping the oil from leaking out of teh case as it corroded most of the substances he tried to use to build the case haha.
think that means he did try to build the case himself and concidering it failed id call it a bodge
Tbh I think it looks great but is a stupid idea
We were actually talking about a case that Sleinous mentioned a friend had been dealing with, not the pictured build earlier.
