sck451
Yep, it's exactly the same case, but with different fans and front panel. (You can actually buy the front panels and swap between them as they're interchangeable.) And yes, the airflow front panel is much better: the glass panel is reasonably good by the standards of cases with solid front panels as it does have decent air gaps around the glass panel, but the airflow option is definitely superior from that point of view.Not ordered yet from amazon, the x version is tempered glass though and i would have thought having a mesh front is better for airflow? i cant imagine having glass covering yoru fans at the front is a good thing....
The x variant is also alot more expensive so the question is , is it really worth it and the only reason it is is because of the tempered glass front and preinstalled fans?
One last thing (and you might be well aware of this already, so please forgive me if I'm stating the bleeding obvious) is that there are both 5000D and 5000D Airflow cases: the former is significantly worse than the Airflow one (as well as being less pretty), so do be careful which you order!
Oh, and when it arrives, please share pictures in the showing off forum.
