EmmaWilliamson688
Hi all. I'm looking to upgrade to a desktop from my laptop since my Razerblade pro battery bloated and im finding that using a laptop as a main pc all day isnt ideal (or at least ....razer ones arent lol). I could get it repaired and maybe i will but have to send it all the way to Germany to razer and might take forever. They dotn send replacement batteries and if i order an aftermarket one myself from china it will take months.
Anyway, I figured it was time to return to the desktop world for something more powerful that is quite happy being on all day. I work as a 3d modeller and love to game and stream aswell. For this i want something that is going to be powerful for rendering, should something happen where i have to freelance and do that myself. A good GPU is a must and my budget will accommodate this. The reason i havnt opted for a quadro is because it might be out of my budget and i also want to game so a 3090 is what im considering.
I realise that the 3080TI might be on the horizon soon but until i know its pricing and performance i am unsure if i should switch to that to save money. I see that 3080 seems to be a long wait aswell. I definitely want this pc to last but also leave room for upgrading in the future if needed , but hopefully if i go 3090 that wont be needed for a long time. Here is my spec of choice if anyone can take a look. I'm a little unsure about the case choice, i want something with good airflow to keep the gpu and cpu running smooth but reasonably quiet for when i stream, the other option i considered was the coolermaster h500 but i prefer the look of the corsair (would love it if they ever stocked the white one).
CORSAIR 5000D AIRFLOW TEMPERED GLASS GAMING CASE
24GB ASUS ROG STRIX GEFORCE RTX 3090 - HDMI, DP
2TB SEAGATE BARRACUDA 120 2.5" SSD, (up to 560MB/sR | 540MB/sW)
2TB SAMSUNG 970 EVO PLUS M.2, PCIe NVMe (up to 3500MB/R, 3300MB/W)
Corsair H100i ELITE CAPELLIX RGB Hydro Series High Performance CPU Cooler
LED Lighting
50cm UV LED Strip
3x Corsair LL120 RGB LED Fan + Controller Kit
Windows 10 Professional 64 Bit - inc. Single Licence [MUP-00003]
SCOTTISH HIGHLANDS & UK OFFSHORE ISLANDS / N IRELAND
Welcome Book
Price: £4,205.00 including VAT and Delivery
LED Lighting
50cm UV LED Strip
Welcome Book
