My First Custom PC
LiaEva
So I got into PC gaming around 5 years ago using an old computer I was given off my brother. So I've finally decided to treat myself but being a worrier I'm just nervous that I could've done better with my budget, what do you guys think?
I don't play many games that require a super computer.
Thanks guys 😁
LiaEva
Case PCS PRISM-X RGB MID TOWER CASE
Processor (CPU)AMD Ryzen 5 3600X Six Core CPU (3.8GHz-4.4GHz/36MB CACHE/AM4)
MotherboardASUS® ROG STRIX B450-F GAMING (DDR4, USB 3.1, 6Gb/s) - RGB Ready!
Memory (RAM)32GB Corsair VENGEANCE DDR4 2666MHz (2 x 16GB)
Graphics Card6GB NVIDIA GEFORCE RTX 2060 - HDMI, DP - VR Ready!
1st Storage Drive256GB PCS 2.5" SSD, SATA 6 Gb (500MB/R, 400MB/W)
DVD/BLU-RAY DriveNOT REQUIRED
Power SupplyCORSAIR 550W TXm SERIES™ SEMI-MODULAR 80 PLUS® GOLD, ULTRA QUIET
Processor CoolingCorsair H100x Hydro Series High Performance CPU Cooler
Extra Case Fans1x 120mm Thermaltake TOUGHFAN 12 Case Fan
InsuranceSimplesurance Purchase Protection inc. Accidental Damage & Theft
MrWilson
Hey,
What is your budget?
Any uses besides gaming? e.g Streaming, photoshop, design etc
What monitor do you have? Make/model or resolution and refresh rate would be handy to know.
LiaEva
1200 plus the Vat and Delivery I paid which is probably my budget because I've got a littlen on his way.
I use the Acer Nitro VG240YP, and I do a little bit of video editing in my spare time.
Thanks your your reply
JUNI0R
CasePCS PRISM-X RGB MID TOWER CASE
Do you have a link to this build? it makes making changes a lot easier!
JUNI0R
I've ordered my build so is it possible? I didn't know about this forum when I ordered it 🤦‍♂️
Go to your Account page, scroll to order Details for this build, press show on actions, then scroll again untill you see a button that says post to forums. Copy the link that it gives you on the bottom of that page and post it in here!
JUNI0R
As you've specced your computer under the HOME / OFFICE COMPUTERS category, you'll have to contact PCS to get it changed to a AMD® RYZEN EXTREME COMPUTERS for the changes we'd recommend. But I'll do one of those builds for you so you know what to change when it's transferred
It's a little over budget, but I've made changes that means it should last a while. if you have a windows key on your previous computer from your brother, you can transfer the license which would save you a lot as you wouldn't have to buy it again. If this is the case, let us know and we might be able to improve it a little
PCS SPECTRUM RGB MID TOWER CASE
ASUS® PRIME B550-PLUS (DDR4, USB 3.2, 6Gb/s) - ARGB Ready!
256GB PCS PCIe M.2 SSD (1900 MB/R, 1100 MB/W)
STANDARD AMD CPU COOLER
Price: £1,239.00 including VAT and Delivery
Unique URL to re-configure: https://www.pcspecialist.co.uk/saved-configurations/amd-am4-gen3-pc/YN!UTfKjC5/
LiaEva
Thank you very much 😁
JUNI0R
No worries! If you are able to transfer the windows copy, this is the build I'd suggest. It comes with a generation newer CPU and faster RAM for a big mac meal less!
NO RECOVERY MEDIA REQUIRED
Price: £1,233.00 including VAT and Delivery
Unique URL to re-configure: https://www.pcspecialist.co.uk/saved-configurations/amd-am4-gen3-pc/BDZQVvDxVB/
LiaEva
Sorry to bother
I've messaged them and hopefully they get back to me 😁 thanks for you
Sorry to bother you again, is it important to change my computer to the Ryzen Extreme? Everytime I contact PCS i never get a reply
JUNI0R
Sorry to bother
No worries! For the best gaming PC for your budget you'll want to change to it as it'll unlock way faster RAM (which Ryzen CPU's love) Sadly since recommended chaning I've since heard you'll have to cancel and re-order. Depending on how far through the queue you are this may or may not be worth it for you, that's your decision but one I'd recommend. If you decide against we can still help you make changes.
Also PCS are extremly busy with customer support since the pandemic started and emails are taking a number of days to reply to. The phone lines also have very long queues (Hour plus queues). If you're able to wait on hold while doing something else, I highly recommend doing this. You could also call them as soon as they open on monday (9am) to increase the liklihood that you get straight through to someone who can sort the situation out
LiaEva
Unfortunately I've been in the queue for 40 days and I think they only let you cancel within 40 days :(
JUNI0R
That's a shame, and also slightly surprising, again, might be worth a call to see if they can do anything for you. I'll work on a build for you if you're unable to get anything sorted
Oh and do they sell any good pre builds? Or is it not recommended
All PCS builds are pre-builds, you choose the parts then they build it, install windows, stress test it and ship it to you ready to go out the box. They sell pre-configured systems but there's always something not quite right about them so we generally recommend going completly custom from the beginning
JUNI0R
This build has ended up being a half decent little machine, the only thing that really needs changing is the ram, but I wouldn't be too fussed if you can't get it worked out. I'll note the changes here:
-Case upgraded to a 220T which comes with 3 fans and great airflow
-Motherboard upgraded to a B550 board as the B450 was out of stock
-Graphics card now a 2060 super as the 2060 is out of stock
-Changed the SSD to a 2TB hard drive and added a 512gb m.2 SSD (this is a seperate option so make sure you change the right one)
-Power supply upgraded to a RMX 850 as the RM750 (the one I wouldve chosen) is out of stock
-Removed the CPU cooler, the standard one is fine
-Removed the thermal paste, standard stuff is fine
-Removed the extra case fan
-Added a WiFi card that also has bluetooth
This build is slightly over budget but can be taken under in a number of ways. The case can be changed back to the Spectrum RGB recommended earlier or if you don't need wifi the wifi card can be removed to save a few. This machine should be an awesome little performer, especially with your monitor, 1080p 144hz will be sweet on the 2060 super!
Price: £1,211.00 including VAT and Delivery
Unique URL to re-configure: https://www.pcspecialist.co.uk/saved-configurations/amd-am4-home-office/TMjwavjdYZ/
LiaEva
Thank you for all your replies, I appreciate all of it 😁
I will ring them and see what they can do
LiaEva
Hi Junior, sorry I'm a huge pain, but I've managed to cancel my order and now I'm looking to start afresh.
This time I'm willing to have a budget of 1350, willing to go abit higher if you think it is necessary. I don't need a windows license because I have one available and I use an Ethernet cable. With luck what I want is in stock and the delivery would be shorter 😁
Sorry I've been a nuisance to you and I'm really grateful for you taking your time to help me out, you're a credit to this forum!
Thank you dearly
