Also I've noticed a lot of builds having a smaller SSD and then an HDD as secondary storage, rather than this suggested build with 1TB SDD. Is that a better way to go?
Normally if budget allows, what we would normally spec is as follows:Also I've noticed a lot of builds having a smaller SSD and then an HDD as secondary storage, rather than this suggested build with 1TB SDD. Is that a better way to go?
I did take few bits from it and the post after and Steveyg's does look good. Might need to pretends to the wife it's cheaper than it is 😂This is personal preference but good advice practice. Some recommend two drives as what you do is on the smaller fast drive you your operating system and applications. Then on larger drive, can still be a fast one, put your games and files etc.
This way then when you need to do a clean install of windows you don’t lose all your files / game downloads etc.
Steveyg suggested such a build earlier but you seem to have missed that.
Oh those wife things do cause problems................I did take few bits from it and the post after and Steveyg's does look good. Might need to pretends to the wife it's cheaper than it is 😂
I'd go with @Steveyg build then if you have budget autorisation..............Well I've just discussed it with her and she agrees it's better to spend a bit more so we will get few years use before needing to upgrade so my budget is now £1500 for the PC itself which is pretty close to Steveyg's suggested build £1484.
Also if you can hold out till nov 30th for the monitor amazon usally have some cracking deals on monitors black friday sale ! For gaming I would stick with the 5600x over the 3700x 5600x is newer chip 3700x is last generationI think the G5 would be sufficient enough to be honest.
Ok, just a couple of little tweaks, you didn't need the 570 motherboard with the 5600x, so I've reduced it to the the 550, which has freed up some cash to give you a really fast boot drive & couple of quid for a coffeeHi again, think I have settled on this build thanks to suggestions from a few guys on here. Would be grateful for any further feedback before ordering. Looking at the G5 monitor just for information and my planned use is mentioned in my original post. Thanks again.
ASUS® TUF X570-PLUS GAMING WIFI (USB 3.2 Gen 2, PCIe 4.0, CrossFireX) - RGB Ready!
512GB INTEL® 670p M.2 NVMe PCIe SSD (up to 3000MB/sR | 1600MB/sW)
STANDARD AMD CPU COOLER
NOT REQUIRED
SCOTTISH HIGHLANDS & UK OFFSHORE ISLANDS / N IRELAND
Standard Build - Approximately 16 to 19 working days
Price: £1,583.00 including VAT and Delivery
Unique URL to re-configure: https://www.pcspecialist.co.uk/saved-configurations/amd-am4-gen3-pc/aVuTYGYfXV/
Speed (by around 3x in some scenarios) and reliability (185TBW for the Intel vs 300TBW for the Samsung). The Intel is kind of mid-range, decent but unexciting, whereas the Samsung is just about top-line (the Seagate Firecuda 530 is possibly a tiny bit ahead -- greater endurance but slightly lower raw speed). Honestly, they're both fine, but for the difference in price, I personally would go for the Samsung.Almost finalised but can I ask if there's much difference apart from price between the 512 GB INTEL 670p and the 500GB Samsung 980 PRO?
Samsung 980 Pro is a Gen4 M.2 so it can make use of the coming Smart Access Memory and it's significantly fasterAlmost finalised but can I ask if there's much difference apart from price between the 512 GB INTEL 670p and the 500GB Samsung 980 PRO?
