Iconico RTX 3070 Awful Performance
angelo994
Your bench result report hight usage CPU in background. Also did you use dGPU only ? Because the bench did not report any Intel GPU while mine show it (MSHybrid mode). Can't help much more sadly.
Yes, at first the benchmark program didn't even pick up my RTX 3070, the program skipped the card altogether (warning skipping graphics card Nvida RTX3070 unable to located attached display). So I went into Nvida Control panel and prioritised the RTX 3070.
Your windows isn’t configured if that’s the case.
angelo994
When you installed windows did you install the supplied PCS drivers or did you get all your drivers from windows update?
For my 3rd install I followed @Romain337 step-by-step. I made sure I did all my windows updates, installed nvidia Geforce, installed control centre, then did benchmark.
Also, where are you sourcing the gpu drivers? Have you got a link?
sorry to ask but you are installing the mobile drivers rather than desktop?
angelo994
Just try installing the Intel updater from here:
I wonder if the chipset drivers are incompatible.
I installed this but it only installed drivers for my integrated graphics card, bluetooth and wireless drivers. I ran another benchmark. CPU still extremely poor.
Romain337
Your CPU turbo is locked to 1.75Ghz in this one. In your first benchmark your cpu turbo is locked to 2Ghz. Even with a windows with no drivers the CPU is not locked like that. Maybe check the windows power settings and all.
Otherwise you can restart from the begining and check when the lock happen (using the task manager).
If it is locked right after the windows install, that could be some CPU tweak done with XTU or something else that got into the BIOS... did you used XTU or something like that ? I cannot provide much more help than that. Good luck.
barlew
There is something very strange going on here.
To me those results say that your Windows is not configured but if you have done everything you say you have then Windows must be configured correctly. Which leads me to believe there is something fundamentally wrong with the laptop and it needs to go back?
angelo994
Yeah I think my only solution right now is to send it back to PC Specialist for them to inspect themselves. It really sucks.
angelo994
Sorry I’m not sure what XTU is. And I’m a bit scared to mess with the Bios in case I mess things up further. Thanks for your advice though
angelo994
So unfortunately I’ve had to schedule a RMA for this Monday. Quite disappointed with this overall. Hopefully I’m not gonna have to wait a long while for the repairs to be made.
barlew
I really hope they turn this around quickly for you mate. I know how disappointing it is to have to RMA a laptop straight after receiving it.
