TomBerry
Same thing, non-EU to EU shippingIt's not due to Ireland being in the EU. It because of the UK not being in the EU![]()
No, it's not the same. Geopolitically it was incorrect. The first sentence made an impression of the change from Ireland side, while the changes and inconveniences is due to the UK.Same thing, non-EU to EU shipping![]()
Edited the OP to avoid confusionNo, it's not the same. Geopolitically it was incorrect. The first sentence made an impression of the change from Ireland side, while the changes and inconveniences is due to the UK.
Uk near Manchester.Where are the PCS products shipped from?
Solid, i shouldnt have problems with shipping as im in UKUk near Manchester.
You get it with DPD who are generally pretty good.Solid, i shouldnt have problems with shipping as im in UK
Unfortunately ive had one terrible experience with DPD but hopefully they redeem themselves.You get it with DPD who are generally pretty good.
Ahh, now I will sleep betterEdited the OP to avoid confusion
The size and weight of the build. Any water cooled or oversized case will go on a pallet.I’ve seen some shipping on pallets. What decides the different delivery option?
Same here but got through on third occasion. UselessYeah got cut off twice after waiting 20 minutes on the line
It's most likely your phone provider cutting you off. The PCS customer care manager has stated a couple of times on here in the past that PCS staff NEVER cut calls off.Same here but got through on third occasion. Useless
I was talking about FedEx. PCS answered almost immediately both times I phonedIt's most likely your phone provider cutting you off. The PCS customer care manager has stated a couple of times on here in the past that PCS staff NEVER cut calls off.
Ah. Apologies in that case. Same answer really though, it's generally the service provider who will cut you off after a time if they detect nothing on the line....I was talking about FedEx. PCS answered almost immediately both times I phoned
