Good spec for general use and light gaming?
If you're spending a bit more on the storage I would opt for the 500gb 980 pro as the primary, with the 1TB Intel 670 as the secondary. Makes more sense to have a faster primary drive.
MK10
Intel® Core™ i5 10-Core Processor i5-12600KF (3.7GHz) 20MB Cache
Get Monster Hunter: Rise & more with select Intel® Core™ Processors
4GB NVIDIA GEFORCE GTX 1650 - HDMI
2nd M.2 SSD Drive
1TB INTEL® 670p M.2 NVMe PCIe SSD (up to 3500MB/sR | 2500MB/sW) (Special Offer)
Corsair iCUE H115i RGB PRO XT Hydro Series High Performance CPU Cooler
Microsoft® Edge
Anything else need changing?
No that looks spot on. I think you will be very happy. It's set up for a high end GPU as well so if you ever wanted to up the capacity for gaming, all you need to do is drop in an appropriate GPU :)
MK10
Thank you, also quick question, is the motherboard which I picked good enough for the PC or should I consider purchasing the ASUS® ROG STRIX Z690-A GAMING WIFI D4 (LGA1700, USB 3.2, PCIe 5.0) - ARGB Ready?
Rather than upgrading the board, if you have spare cash, I would personally put it into the GPU as the 1650 is pretty weak by todays standards.
What monitor are you pairing this with, what make and model?
MK10
Gaming wont be a priority for me which is why I picked a weak GPU, I'll probably game max twice a week.
MK10
The specification below has been formatted so you can easily copy and paste this to our forums when discussing your specification. Once you've copied the specification, please click here to continue.
Intel® Core™ i5 10-Core Processor i5-12600K (3.7GHz) 20MB Cache
250GB SAMSUNG 970 EVO PLUS M.2, PCIe NVMe (up to 3500MB/R, 2300MB/W)
512GB INTEL® 670p M.2 NVMe PCIe SSD (up to 3000MB/sR, 1600MB/sW)
Microsoft® Edge
Price: £1,100.00 including VAT and Delivery
Unique URL to re-configure: https://www.pcspecialist.co.uk/saved-configurations/intel-z690-pc/0ZwNQ4kG7a/
sck451
I guess it would depend on what the intensive programming tasks are!
It's definitely a good PC for general programming tasks, e.g. web development and stuff. If you're compiling the Linux kernel three times a day, less so. In either case there are things I'd tweak, such as the cooler and storage.
MK10
What would you change the cooler and storage to?
MK10
What softwares are you using? Without knowing the specific load intentions it's hard to give concrete advice.
I'll be using Virtual Machine, PHP Storm, Kali Linux, Ubuntu, Github etc. I'm going for the software developer role and the PC will mainly be used for general use as well as coding.
That's not exactly light use then 😉
What VMs are you running as that will hugely affect the specs?
Actually scrap the VM I wont be using it. What would the final specs then look like without the VM being included?
Ok, it doesn't sound like you're fully sure of what you need.
I'll highlight the reasons for the questions:
If you're doing any kind of virtual work, you want high core count and high RAM as each VM will require dedicated threads and RAM. Intel sucks for VMs because of the way the CPU is designed in a big/little config. The E cores (efficiency) are simply Atom cores, as soon as offload any kind of virtualisation process to these cores, performance is gonna tank. So it's only the P cores that have any relevance. As such Ryzen would be a far better option
And then you need to imagine what kinds of VM's you're going be running. Will they be Linux or Windows as that will affect resources requires for the OS, then what are they hosting? You need to factor in if you're doing professional domain level programming, or end user? If business level, then you'd want secondary VM's with business platforms running to test compatiblity with your code alongside whatever professional environments the company uses. Etc etc etc.
If this is a new role for you, you want to overspec because what you think your requirements are now, I guarantee will change and you want to be prepared for anything that comes your way. Don't think of your requirements now, think of 7 years down the line.
MK10
8GB NVIDIA GEFORCE RTX 3050 - HDMI, DP, LHR
512GB INTEL® 760p M.2 NVMe PCIe SSD (up to 3230MB/sR | 1625MB/sW)
Microsoft® Edge
Price: £1,527.00 including VAT and Delivery
Unique URL to re-configure: https://www.pcspecialist.co.uk/saved-configurations/intel-z690-pc/NUyQbDn5zW/
Microsoft® Edge
Did you read the above? If you're doing development then you will unquestionably be using vms.
MK10
PCS SPECTRUM G ARGB MID TOWER CASE
Intel® Core™ i7 12-Core Processor i7-12700F (2.1GHz) 25MB Cache
CORSAIR 750W CX-M Series™ SEMI-MODULAR 80 PLUS® BRONZE
Microsoft® Edge
Price: £1,363.00 including VAT and Delivery
Unique URL to re-configure: https://www.pcspecialist.co.uk/saved-configurations/intel-z690-pc/3DfPMpyswC/
