I didn't, I guess I could now I know exactly what my OC settings should be though.
baron, I don't have battlefield 3 no...
I do have Skyrim/The Witcher 2/Crysis 2 and a fair few other high end games. Why do you ask?
Heaven Benchmark v3.0 Basic
FPS: 47.1
Scores: 1187
Min FPS: 13.6
Max FPS: 120.2
Render: direct3d11
Mode: 1920x1080 8xAA fullscreen
Shaders: high
Textures: high
Filter: trilinear
Anisotropy: 16x
Occlusion: enabled
Refraction: enabled
Volumetric: enabled
Tessellation: extreme
3dmark11
(a little higher than the very first time i tried it)
http://3dmark.com/3dm11/3479461
P9822 3DMarks
Graphics Score: 9840
Physics Score: 11542
3dmark06
(strangely, this ones about 500 lower than the first time I tried it)
http://3dmark.com/3dm06/16676953
33848 3DMarks
Passmark
4731.9
CPU: 13000
3d Graphics: 785.7
2d Graphics: 4519.4
Retest of heaven
Retested with fans set to actually go above the 30% they never seem to go over on auto...
FPS: 47.4
Scores: 1194
Min FPS: 22.7
Max FPS: 121.3
in heaven, actually scored about 60 points less in 3dmark.
Here are my benchmark results for pretty much every benchmarking app I have access to, I did turn on the witcher 2 and had a go at it with everything maxed out (including having ubersampling on) and it played fairly smooth, what should i use to measure its fps? the game doesn't have an fps option that I knew of? I might have a save at the point you mean, so i can do that later. I'll have to test crysis2/skyrim as requested, in skyrims case I have it set to ugridload = 7 instead of its default 5, and use a couple of other ini tweaks + the hd textures DLC.
In Heavens bencmark, the main thing I noticed was that compared to a guy with very similar spec machine, my minimum fps was 1 higher (in the first setting) and 10 higher with fans set to max, while my max was 4 lower and my average was a couple lower - score was a few hundred lower too.
FPS: 47.1
Scores: 1187
Min FPS: 13.6
Max FPS: 120.2
Baron, would you mind running heaven again, but with 16x Anisotropy and 8x antialiasing? That'll make it the same settings I used... was your CPU overclocked? interesting and I notice you have 2x 580s correct?
thanks Buzz, I'll do that when I get home!
+rep to you both for helping a lot![]()
some impressive scores! I'd expect them to be higher than mine still as you're running in SLI. Still would be nice if I could get my 680 to perform on par with other peoples 680s...
Just curious to know what do you mean by that.but people laughed at me for going for the GTX580 SLI setup & not going for the GTX 680 instead , but the benches are still proving i wasn't wrong to go the way
Rubensolo, he's saying that his SLI 580s are out performing a single 680, which is correct judging from his benchmarks!![]()
