Difference between SSD and 2.M SSD
VenatoS
Mine was great, but I guess it depends what case you get, as some cases have better set ups for cable management.
Alright, thanks. Yeah i've searched back to about 10th ish pages and i saw people making some positive comments in general when it comes to cable management.
Another question if anyone knows. What is my chance of actually getting the GTX 780 ti Palit over the stock one?
VenatoS
Does anyone know how long usually the "Processing" stage takes? :D
I'm patiently waiting for new PC !
steaky360
Processing is often the longest part of the build as you're essentially in a queue for your order to be picked and built!
Don't worry though, 'building' is typically a LOT faster! :)
EDIT: I am referring to Pre-Production here, not processing. Sorry.
VenatoS
Atleast building wont take long but it says "Processing" will take 1-6 days ... and THEN pre-production 1< week e.e
A lot of waiting :/
steaky360
A lot of waiting :/
I must confess, I was talking about Pre-Production in my previous statement :( Not Processing... Processing doesn't usually take all that long......
Sorry :(:(
VenatoS
Sorry :(:(
Its alright :D !
I rather wait and get a good product then rush it :p
I'll be patient!
Thanks steak360 :D
VenatoS
SSD & HDD partition
Hello i really need an answer!
My PC is in Pre-Production stage ia it still possible for me to set partitions?!
Also how would you recommend me to partition my ssd and hdd.
240GB ssd (i want it to have separate partitioom that will hold windows 7 and other for storage of applications that i use often)
1TB (I want to keep it as a whole)
vanthus
Member Resting in Peace
You can probably still amend your order,but personally I can't see any real advantage in partitioning.
GeorgeHillier
Why do you need a partition? It won't make a difference in performance or anything like that...
VenatoS
i just dont want to by accident install something into my windows.folder or something just thought.it would be good to make the separate.
VenatoS
Is the Caviar black loud? Ive seen couple youtube videos and the noise seemed horrible!
Anyone that owns one or had one can confirm?
