3. Both of these drives seem to have same spec, but MUCH different prices.... why?
2TB WD CAVIAR BLACK 6 GB/s 2,000 GB 7,200 RPM 64 MB
2TB 3.5" SATA-III 6GB/s 6 Gb/s 2,000 GB 7,200 RPM 64 MB
Is that the 2TB Caviar black is extremely expensive! I want a fast, silent HHD, (2tb storing a lot of games)
By silent i do mean just quiet.
Depending on how quiet you mean, the caviar black might be fine. It doesn't sound like a helicopter or anything... but equally you can hear it over the PC's fans occasionally for example. If you're gaming though I highly doubt it'll bug you.
yeah, that is all i need to know. I'm just not sure if i should go for the caviar black as it is pretty expensive but will it be such a major difference when i will be playing games.
it is your choice at the end of the day. I personally would go with the caviar black rather than overclocking my cpu if I have a tight budget. I wouldn't skimp on the drive, how significant? I can't be sure but compare to a barracuda drive for me it is noticeable.
I suspect you'll get whatever colour they happen to have in at the time.Since Kingston Hyper X Fury RAM has different colors will PCs try to match the colors to my system? E.G get the white ones since i have a white case
