Big navi 21. PCS release info?
GCColes
This may not be the right place to post but though id ask on this thread first.
The GPU (Merc 319 6800XT) in my system, has 2 8-pin connectors, it seems to be connected via a single pcie 8-pin and 6+2pin cable to the PSU. Should it have 2 cables from the PSU to ensure proper power draw. PSU is RM850x, i haven't noticed any issue with the system running so far but wondered if it is a potential issue?
matt3
hi guys,
don't know if this helps anyone with their build queues, however i ordered my PC on 30th Dec and it went into building this morning (didn't know they do that on a Saturday), after 23 WD. As a matter of fact it moved into testing an hour ago (!!!!). For reference i've ordered a 5600x with AMD 6800, however i suspect that what was holding it back was the case (Coolermaster H500 ARGB) which i believe came back in stock yesterday!!!
I'm beyond excited!
Vinceptic
Dear forum member,
So have had my pc since tuesday now i have a 6800XT and a 5800x in my build and all i can say is guys dont change your orders it is worth the wait 100 percent i have been blown away every day since tuesday.
I was one of the people that after waiting for about a month i was becoming very inpatient, i ordered on december 12th and recieved it here on february 2.
But honestly if you ordered a amd gpu and cpu i have noticed orders are getting delivered quiet a bit faster than the nvidia orders because i feel like most people still dont wanne go all amd wich is understandable but i dont care about raystracing and i have always wanted to try a amd gpu.
I can tell you the 6800XT is worth every penny i payed for it and same with the cpu i am abolutly blown away and i also wanne apoligise to pc specialist and the forum for bitching a bit to much in the past.
Also the radeon software is great and really ez to use.
I hope everyone gets his builds soon and just be patient it is worth the wait.
Kind regards vinceptic
I did want to go all AMD, but after realising I'd never get an RTX3080 before Christmas, I upgraded from a 3600X to a 5600X the moment they became available on PCS, and then to a 6800XT the moment they became available on PCS.
Still didn't see any movement for another 4 weeks, and needed it before the year end to take advantage of a company grant for homeworkers (which has been extended now, due to further lockdowns), so called up and asked what was actually in stock for quick build/delivery.
I finally ended up with an RTX3070 and 5800X...which I'm very happy with.
