I thought they were a gold mine even for the 3090s. For 300 or 400 pounds more I actually don't know if I should go for it.Guess they're plentiful for 3090s due to the price.
It's about £970 more to go from 3080 Rog Strix to 3090 Rog Strix.I thought they were a gold mine even for the 3090s. For 300 or 400 pounds more I actually don't know if I should go for it.
And it's €1027 more to go from RX6800XT to RTX3090.It's about £970 more to go from 3080 Rog Strix to 3090 Rog Strix.
Well from a 3090 to 3090 strix is 397 if I recall it correctly. My budget is way over nowIt's about £970 more to go from 3080 Rog Strix to 3090 Rog Strix.
You are right. But for CAD applications is actually really helpful. I definitely need itAnd it's €1027 more to go from RX6800XT to RTX3090.
Not worth it, in my opinion, for a 16 percent improvement.
Yeah, you need to be careful, I almost went AMD but I discovered that Autodesk Maya didn't currently support AMDs new cards. And that Maya is the main application I am using on my computerYou are right. But for CAD applications is actually really helpful. I definitely need it
In building today after 32 working days with a 5900x and 3060ti. 😄
Must be something else then.
Now 40 working days and still in pre-production.
My 5900x and 3080 just went into build yesterday @ 92 days65 days in with a 5900x and 3080.
I pray its ready by next month, I have a film to edit![]()
It's the 5950 holding you up. You'd have been done a while ago if you'd stuck to 5900.85 days 3090/5950x. Upgraded from 3080/5900x as they said it would be faster but doesnt look like it is going to be, may end up downgrading back to 3080 as people on that thread getting their builds between 90-100 approx
I was told few days ago that they gonna get some 5950x around end of march but we shall see if that is the caseI suspect looking at people recently receiving their orders that you are correct - but it saddens me that people on forums give better advice than PCS themself who specifically told me that the 5950 was in stock and less in demand than the 5900, hence the change
