SamuelEdwards161
This is fantastic! Thankyou so much. Would you recommend this over the the above Ryzen 9 build you posted? Do you reckon there will be much of a performance dip between your above post with the Ryzen 9 and this one?Below keeps everything inside budget and is filled with knowns, rather than unknowns. It also allows for the luxurious storage and with the savings you could afford a G5 monitor.
8GB NVIDIA GEFORCE RTX 3060 Ti - HDMI, DP
Corsair Gaming Bundle - K55 Keyboard, M55 PRO Mouse, HS35 Headset & MM100 Mouse Mat
Standard Build - Approximately 14 to 16 working days
Price: £2,429.00 including VAT and Delivery
Unique URL to re-configure: https://www.pcspecialist.co.uk/saved-configurations/amd-am4-gen3-pc/ehw08mU!4p/
If not I might well go with this and the G3!
Thanks a bunch man!
