Hi
As you can see I am using WIRELESS INTEL® Wi-Fi 6 AX200 2,400Mbps/5GHz, 300Mbps/2.4GHz PCI-E CARD BT 5.0
I am moved my computer to the other room and I can't get a wi-fi range at all. I also have problem with Bluetooth. My Sony WH-1000XM3 and other headphones keep dropping signal all the time even when I am very close to the computer. I don't know if it's the computer case or the built in wireless. I might have to upgrade it.
Another question, is my sound card upgradable? I am using Sennheiser 660s connected straight to the back of the PC. Would your recommend to have a better sound card?
CORSAIR CRYSTAL SERIES 680X RGB GAMING CASE
8GB NVIDIA GEFORCE RTX 2080 SUPER - HDMI, 3x DP GeForce - RTX VR Ready!
250GB SAMSUNG 970 EVO PLUS M.2, PCIe NVMe (up to 3500MB/R, 2300MB/W)
CORSAIR 750W RM SERIES™ MODULAR 80 PLUS® GOLD, ULTRA QUIET
LED Lighting
2x 50cm RGB LED Strip
Promotional Item
Get Horizon Zero Dawn: Complete Edition with select AMD Ryzen CPUs
Welcome Book
Logo Branding
PCSpecialist Logo
Thanks for your support!
Viktor
LED Lighting
Promotional Item
Welcome Book
Logo Branding
PCSpecialist Logo
Viktor
