What one ?
A wee bit more information would help here - what is your budget, what screen is it being paired with and what games (presumably) are you wanting to run at what settings?
can wiggle with budget, 4k Samsung monitor, not fortnight but like, cod, battlefield, rust, pubg, that kinda games
we can only advise on full systems from PCS, there’s no point advising on singular components because everything works together depending on budget, screen and usage.
If you post your proposed spec we can advise.
Change to: CORSAIR OBSIDIAN SERIES™ 500D SE CASE
Processor (CPU)AMD Ryzen 7 3800X Eight Core CPU (3.9GHz-4.5GHz/36MB CACHE/AM4)
MotherboardASUS® TUF X570-PLUS GAMING (USB 3.2 Gen 2, PCIe 4.0, CrossFireX) - RGB Ready!
Change to: ASUS® CROSSHAIR VIII HERO (DDR4, PCIe 4.0, CrossFireX/SLI) - RGB Ready!
Memory (RAM)16GB Corsair VENGEANCE RGB PRO DDR4 3200MHz (2 x 8GB)
Graphics Card8GB AMD RADEON™ RX 5700 XT - HDMI, DP - DX® 12
Change to: 8GB NVIDIA GEFORCE RTX 2070 SUPER - HDMI, 3x DP GeForce - RTX VR Ready!
1st M.2 SSD Drive1TB INTEL® 660p M.2 NVMe PCIe SSD (upto 1800MB/sR | 1800MB/sW)
Change to: 1TB SAMSUNG 970 EVO PLUS M.2, PCIe NVMe (up to 3500MB/R, 3300MB/W)
DVD/BLU-RAY DriveNOT REQUIRED
Power SupplyCORSAIR 650W TXm SERIES™ SEMI-MODULAR 80 PLUS® GOLD, ULTRA QUIET
Change to: CORSAIR 750W RMx SERIES™ MODULAR 80 PLUS® GOLD, ULTRA QUIET
Processor CoolingCorsair H100i RGB PLATINUM Hydro Series High Performance CPU Cooler
Change to: ARCTIC MX-4 EXTREME THERMAL CONDUCTIVITY COMPOUND
Wireless/Wired NetworkingWIRELESS INTEL® Wi-Fi 6 AX200 2,400Mbps/5GHz, 300Mbps/2.4GHz PCI-E CARD + BT 5.0
The 5700xt isn’t going to be able to push 4k 60hz, you’d need a 2080 Super for that. But there’s a lot that can be rebalanced to fit the higher card in that budget.
This is better balanced, at 4k there's going to be no difference between a 3600 and a 3950x, the power is shifted to the GPU:
AMD Ryzen 7 3700X Eight Core CPU (3.6GHz-4.4GHz/36MB CACHE/AM4)
8GB NVIDIA GEFORCE RTX 2080 SUPER - HDMI, 3x DP GeForce - RTX VR Ready!
NOT REQUIRED
STANDARD AMD CPU COOLER
NO RECOVERY MEDIA REQUIRED
Firefox™
Price: £1,985.00 including VAT and Delivery
Unique URL to re-configure: https://www.pcspecialist.co.uk/saved-configurations/amd-am4-gen3-pc/gRyjvGKJxp/
NOT REQUIRED
Firefox™
This work ?
Change to: ASUS® ROG STRIX X570-F GAMING (USB 3.2 Gen 2, PCIe 4.0) - RGB Ready!
Change to: 8GB NVIDIA GEFORCE RTX 2080 SUPER - HDMI, 3x DP GeForce - RTX VR Ready!
This work ?
So you completely ignored the previous advice?
