What do ye guys think of this?
MoonIsB
It would come with a test version of win 10, which you cant/really really should not use (you'll have all sorts of issues)
Basically, create a boot usb using media creation tool, and install windows as a fresh install when you get it.
Do you happen to know how big the windows install would come to?
Deleted member 17413
You need a USB drive with at least 8Gb on it, creating the boot usb will wipe it first so dont use anything that has stuff you want to keep on it.
MoonIsB
After putting in the boot drive does that pc need an internet connection is that usb enough
It will ask for internet during setup, and you will need internet anyway as you would then have to run windows update repeatedly to finish configuring.
The USB basically has the starting components and instructions (for want of a better way of putting it)
MoonIsB
Yeah
What worries me about that is I usually tether off of my mobile for decent internet so I dunno if packet loss affects the download quality and wouldnt wanna muck it up just cause I used my phone internet
[Edited by ubuysa for language]
@sibun1 Do you know if I purchase the key if they do all the windows updates and install it?
It will come pre-installed if purchased. You will just have to do usual windows set up for the first time. it's then recommended that you perform windows updates and GPU updates as well once your set up.
If you select the No OS required it will come with a test version of windows but you will need to do a fresh install on from a USB as it likely won't be set up properly and cause issues if you use that version
A Windows 10 install can range from (roughly) 25 to 40 GB depending on the version and flavour of Windows 10 being installed. Home, Pro, Enterprise etc. The Windows 10 ISO installation media is approximately 3.5 GB in size. Once windows is installed you will need to update it
You should look into 4g home broadband is a good alternative to a broadband line does not require a phone line
MoonIsB
Is there any benefit to doing that over just using my mobile to tether I get unlimited data and top up each month anyways are they known to be better?
A friend uses one and is exstremely happy with his d/l rate tho I dont know a whole lot on the subject I use broadband with a landline was just suggesting a option for you to research
MoonIsB
Yeah I'd have to look into it more probably though I'm not in a big rush to get new internet, just would be a bit nervous doing something this important over my mobile data
MoonIsB
For 1440p 144hz gaming your not going to be able to get it much cheaper at the moment without sacrificing the upgradability of the build.
This build is a little bit more expensive than the one above but will give you better cooling, performance and upgradability which will help lower the cost of the over it's lifespan as you will just need to change the GPU rather than a whole new build
ASUS® PRIME B550-PLUS (DDR4, USB 3.2, 6Gb/s) - ARGB Ready!
8GB NVIDIA GEFORCE RTX 3060 Ti - HDMI, DP
STANDARD AMD CPU COOLER
Price: £1,494.00 including VAT and Delivery
Unique URL to re-configure: https://www.pcspecialist.co.uk/saved-configurations/amd-am4-gen3-pc/aPAQZ6AHsG/
I was looking through the 3060ti build and I noticed the motherboard has only got rear usb am I misreading something here or are some of the back ones routed to the specific places on the case?
it has 6 rear usb ports and can support up to 6 more on the case.
Any case has case USBs, they route to the internal usb headers which all motherboards have.
MoonIsB
Ah right thanks I was looking at the info on the pcs site and only saw 6 rear so I was a bit worried ;D
Ah right I never knew that first pc build im actually looking at the parts and trying to make sure they have what I want even if its only basic stuff
MoonIsB
To be fair, most people wouldn't...I have a reasonable knowledge of motherboards so I know there are more ports than are listed but most people wouldn't so it's confusing
Yeah I'm a bit of a noob when it comes to most parts, while im thinking about the parts do you think I should go with more fans for that case or are 2 pre included alright and am I right in thinking theres no need for silver warranty given the only thing it gives me is delivery and returns since im from ROI and am I right in thinking the delivery cost is included in the price given on the pc list?
