Want an opinion on my order, while I can still amend
baron75mk2
Banned
It says 8x 3.0/2.0 / 12x 2.0
Are you sure, before I cancel the 3.0 card?
That would be 8 , USB 3.0 (Also compatible with USB 2.0) & 12 USB 2.0 ports
so yes the two USB 3.0 ports on the front of the HALF X case will be connected to the midboard ( same with the two USB 2.0 on the front)
& the rest will be at the back ( at leased its this way on mine ) - doesnt look like you need that PCI card to me - good thing , more spacing between the top & bottom cards for SLI , sure you will see setups where they have 2 or 4 of them litteraly on top of eachother & say "of coarse it wont overheat" - yes maybe for half an hour or so - keep at leased half an inch between cards is my way of looking at it & anything more is a bonus.
Cade
Okay, I've cancelled the Card, thanks for the help with that :)
Also, began thinking of what game I can christen my system with when it arrives.
