Hi, I'm a longtime lurker of this board just gathering a lot of information before I decided to finalised my build and with my previous laptop on it's last legs I'm curious to see what you all think of the below spec. It's purpose will be very vary from some gaming, photoshop design or video editing occasionally to more general browsing and a mix of work and fun. I probably want this laptop to last at least 3 years before it gets completely left behind by new technology.
Vortex II: 17.3" Matte Full HD LED Widescreen (1920x1080) (£89)
Intel® Core™i7 Quad Core Mobile Processor i7-2720QM (2.20GHz) 6MB Cache
8GB SAMSUNG 1333MHz SODIMM DDR3 MEMORY (2 x 4GB)
2GB AMD® Radeon® HD 6990M - DirectX® 11 (17.3" Vortex II)
Memory - Hard Disk
160GB INTEL® 320 SERIES SSD, SATA 3 Gb/s (upto 270MB/sR | 165MB/sW)
500GB WD SCORPIO BLACK WD5000BPKT, SATA 3 Gb/s, 16MB CACHE (7200 rpm)
Intel 5.1 Channel High Definition Audio + SPDIF/MIC/Headphone Jack
Bluetooth & Wireless
GIGABIT LAN & KILLER™ 1102 WIRELESS 802.11N - IDEAL FOR ONLINE GAMING
My budget is being a bit stretched by potentially contentious issues such as the whole Matte vs Glossy debate and while im leaning towards Matte I'm still not totally sure of how the end result will fare. I've did a lot of research into this and there's very mixed reviews on the issue of colour accuracy vs reflection or vivid displays and whether Matte's can help reduce eye strain (a primary concern for me as I will use this laptop a lot for work and at home and I'd like to avoid needing glasses for a while :winkiss: ).
I also have opted for an SSD after much thought and chose the Intel 320 160gb over the Intel 510 120gb largely due to the marveaux controller of the 510 and also that a larger size SSD should help extend the life and performance of the 320 even if the 510 is significantly faster overall. I will most likely just have OS, some Key applications and Games on the SSD but will use my secondary drive to hold most data and things like temporary files to try to prolong the SSD's lifespand and quality.
In trying to cut costs I managed to get a legitimate additional license for Windows 7 Premium 64bit, however I'm wondering whether choosing no OS might affect the testing and quality control of the laptop or could I end up having serious issues trying to resolve driver issues (I'm looking at you 6990m!) upon a new OS installation? Perhaps it might be possible to have a free Windows 7 Premium trial on the computer used during testing so then I would only need to use my license key to make it official?
I would appreciate any feedback or alternative ideas anyone might have for my specification and apologies for the mountains of text here! In particular queries about the Screen type, Harddrives, Ram, GPU and Operation system are welcomed and I'm considering upgrading the warranty further.
Many Thanks
Memory - Hard Disk
Many Thanks
