Do you think I can make a better build with ÂŁ1310? With different specs compared to the one I posted yesterday?I will put:
dual channel ram (2x8 instead of 1x16),
no bullguard (it's bad and you doesn't need it), 30 Day Dead Pixel Guarantee,
and if you want change the thermal past with the mx-4.
I think that's all for me 👍🏻
Thanks for the information, I have a quick question, what does the ram do? Does it make the laptop quicker? What's the benefits of having a better ram?I think that you can put faster ram, it's only small addiction. For that money I think that's a good config.
Oh ok thanks a lot for the information đź‘Ť appreciate itI don't know how much it would be faster but it will be definitely faster.
Also, quick question what is the 30 day dead pixel gaurentee about? Also what does the thermal paste do?I don't know how much it would be faster but it will be definitely faster.
Perfect, thanks a lot for the information, I will be going ahead with upgrading it more and make a purchase, appreciate your help 👍💯The dead pixel guarantee is a warranty that if the display arrives with some dead pixel (for some reasons) they change it without problems and you don't have to pay nothing. If you don't have this warranty you have to stay, eventually, with the dead pixels or pay for a substitution of the display. It's only few € and I would recommend. The thermal paste is needed to cool the CPU. Better paste means better temp.View attachment 27443
Sorry, I forgot to attach it, here's the highlights and thanks for all the information you provided meI don't see the highlight texts. However I will remove bullguard antivirus (it's bad) and I think that's all.
Oh ok, thanks for the information, I'll add on these extras and remove the 64gb ram and add 2x32gbs instead and I'll go ahead with the gold warranty aswell, thanks a lotFor the sake of ÂŁ7 more - you might as well have 1 year dead pixel if you are going for it.
Remove Bullguard - as has been mentioned.
You will not need 64gb - I put it in mine and the heaviest I have used was 48% of it - so 32gb will probably be fine for you - depends what you are doing. My heaviest use was 'stitching' several photos into a pano on Lightroom.
When paying that much for the laptop too, I would take out GOLD warranty - 2 year parts then.
Yes, you will get automatically the highlight things with the component you choose.Sorry, I forgot to attach it, here's the highlights and thanks for all the information you provided me
Oh ok i see, you're right, there's no point wasting extra money, I'll go ahead and change that, thanks a lot for the info 👍You don’t need 2 x 32gb. Just 2x16gb or even 2x8 if it’s just gaming.
That's perfect, thanks for the information, appreciate that and all the help you've given me đź‘ŤYes, you will get automatically the highlight things with the component you choose.
