I've got a PC Specialist laptop on order and it should be ready within the next 2 weeks. I've also got another laptop which I need to take the 2.5 ssd hdd out and transfer the data across to my new laptop (old laptop doesn't turn on but I need the data).
I've seen some kits on amazon which house internal 2.5 hdd's and then connect via USB so that you can access the hdd externally but I don't know which one to get.
Can anyone make some recommendations of something which will do the job fine? Some range from £6 all the way to £20 upwards and because its a one off, I want to make sure whatever I order does the job but don't want to pay unnecessarily more.
Thanks in advance!
Thanks in advance!
