Any chance you can check what BIOS version you're on?5900x
Strix X570-F
4x 8GB 3200Mhz Corsair Vengeance (RGB)
6800XT Sapphire Nitro+
Not a single BSOD, almost 3 months in. All good!
sure thing 2.20.1271Any chance you can check what BIOS version you're on?
That's great, thankssure thing 2.20.1271
Forgot to add...version is 2812That's great, thanks![]()
Processor (CPU) | AMD Ryzen 5 5600X Six Core CPU (3.7GHz-4.6GHz/35MB CACHE/AM4) |
Motherboard | ASUS® TUF GAMING B550-PLUS (DDR4, USB 3.2, 6Gb/s) - ARGB Ready! |
Memory (RAM) | 32GB Corsair VENGEANCE DDR4 3600MHz (4 x 8GB) |
Graphics Card | 8GB NVIDIA GEFORCE RTX 3070 - HDMI, DP |
Any x500 board only accepts native speeds up to 3200MHz, the rest is overclocked with DOCP.Looking on the AMD site a Ryzen 5, 5600X only supports RAM up to 3200Mhz
It looks to me as though the main issue has been solved, probably by an updated AGESA/BIOS. We've seen only one issue in the whole month of June.So, from reading the comments, my rough summary is that it appears that only Ryzen 7 5800x is happy with 4 sticks of RAM at 3600MHz. It seems most other AMD CPUs struggle, but possibly a BIOS update/settings change might fix it?
However, it looks like 4 sticks at lower frequencies are more stable.
As stated in that thread, you're very out of date on the BIOS, would be worth calling PCS to get it updated.I'm still having issues, trying to get my RAM to work at a decent speed with 4 sticks in a Ryzen 5950X system; see here (go to the end of the thread) for an update, if you're interested!
