whats the PC for dude?
After Effects CS6 and 3DS mAx
Would that void the warranty? I was thinking about replacing my Spire Thermax with something quieter but if you are allowed I might try new fans first..
Sorry to hijack but seemed like a perfect opportunity....
ANTEC QUIET COMPUTING™ PERFORMANCE P280 CASE
Intel® Core™i7 Quad Core Processor i7-4770 (3.4GHz) 8MB Cache
ASUS® SABERTOOTH Z87: USB 3.0, SATA 6.0GB/s, THERMAL ARMOR
32GB KINGSTON HYPERX BEAST DUAL-DDR3 2400MHz X.M.P (4 x 8GB KIT)
2GB NVIDIA GEFORCE GTX 770 - 2 DVI, HDMI, DP - 3D Vision Ready
240GB INTEL® 520 SERIES SSD, SATA 6 Gb/s (upto 550MB/sR | 520MB/sW)
1TB WD CAVIAR GREEN WD10EZRX, SATA 6 Gb/s, 64MB CACHE (+ I got a 300GB Velociraptor and 1TB WD Black already to add to this)
CORSAIR 750W PRO SERIES™ HX750-80 PLUS® GOLD MODULAR (£119)
Corsair H60 Hydro Series High Performance CPU Cooler (£59)
Like so..
If I remember correctly, PCS encourage upgrading if needed. could be wrong.
The storm trooper is not advertised as a quiet case, the antec you selected before is but you are trading off slightly better cooling for lower noise. I had a Kingston SSD and I never experienced an issue, I doubt you can tell the difference between a Samsung or Kingston SSD unless you are benchmarking.
I want the moat reliable one. Dont want to loose by data in the first month. Am i being paranoid?
Also do u really need the sabertooth MB?
I want a quiet case. Is that quiet?
RAM the more the better for CS6. If my budget was higher would gone for 64gb with the other selection.
Kingston SSD are not great from what ive been reading. Would prefer a samsung series 8 one ... Maybe i can just order that seperatly and add it later
