It's a different Corsair caseA bit too cryptic for me Ash!
What does that mean?
Ah OK thanks I see that now.It's a different Corsair case![]()
Just keep in the same thread if possible, it's important people can see a history of advice to avoid duplicating things.I might move my Q to a new thread to better catch the attention of anyone who has the case already - assuming that’s acceptable forum decorum!
OK no worries will do SpyderTracks. 👍Just keep in the same thread if possible, it's important people can see a history of advice to avoid duplicating things.
Hoorah! Thanks so much AgentCooper!I’ve got the iCue 220T. Great for if you’re not able to accommodate a hulking brute of a case on your desk. Fans at the front are controllable via ASUS Fan Xpert 👍
SpyderTracks - I’m disappointed with your advice here. It took me 3 minutes to get the answer I needed within this thread. I think it would have been much quicker if I started a new topic.Just keep in the same thread if possible, it's important people can see a history of advice to avoid duplicating things.
They should attach everything you’ll need and put iCue on there, it’ll just be the Fan Xpert software you’ll require downloading.Hoorah! Thanks so much AgentCooper!
Out of interest would it arrive from PCS connected correctly for everything to be controllable or will I need to get any bits/do some install work post delivery?
EDIT - I guess I mean did PCS install the fan control leads into the mobo or into Corsairs own little RGB yoke instead....?
Thanks so much for the help AgentC. Much appreciated. 👍👍They should attach everything you’ll need and put iCue on there, it’ll just be the Fan Xpert software you’ll require downloading.
If it’s connected up the same way as mine has been, the RGB on the case fans is controllable via iCue, it just seems to be the actual fan speeds that doesn’t work from that.
No problemo 🙂👍Thanks so much for the help AgentC. Much appreciated. 👍👍
Actually - just one more question if you don't mind....No problemo 🙂👍
Now that one I can’t be 100% on. But in theory, as long as it’s going into the appropriate fan header on the motherboard you should be able to control them via the software.Actually - just one more question if you don't mind....
I'm getting two additional case fans - just the standard cheap black yokes - will I be able to control those also or will all the fans need to be the same model (all Corsair SP120's)?
Just make sure all the rgb cables are managed nicely out the wayNow that one I can’t be 100% on. But in theory, as long as it’s going into the appropriate fan header on the motherboard you should be able to control them via the software.
Personally... I wouldn’t get the cheapo fans, why not pay a bit extra for one of the SP fans and fit it yourself? It’s a quick and easy job to do and you could bathe in the light of even more glorious RGB 🤩
I'm not a huge fan of the whole RGB scene - although some gentle lighting would be nice I guess!!Now that one I can’t be 100% on. But in theory, as long as it’s going into the appropriate fan header on the motherboard you should be able to control them via the software.
I feel that kind of goes without saying, these days 😁Just make sure all the rgb cables are managed nicely out the way![]()
You don’t have to have a full light show going on. I’ve currently got mine set to a nice orange shade which casts a warming glow across the desk 👍I'm not a huge fan of the whole RGB scene - although some gentle lighting would be nice I guess!!
I don't see the SP120's on PCS so I'll have a look around and grab a couple myself as you suggest. Bravo Mr AgentC!
You're right of course - I think I just have all those YouTube videos of desktop laser light displays burned in my retinas at this stage!You don’t have to have a full light show going on. I’ve currently got mine set to a nice orange shade which casts a warming glow across the desk 👍
