Further addition, if you really are set on air cooling, get the Noctua, nothing else is relevant with this chip.
Hello Spyder,As a preliminary suggestion, with notes by components:
This is some more info on tying your windows 10 license to Microsoft account so you can transfer to other builds, works for home and pro, but obviously not volume licensesHello Spyder,
Thank you so much for putting that all together for me, very kind of you.
I did say about preferring air cooling for the CPU, but you are right and I have to say the AIO that I have in one of my current machines (also Corsair) has been happily working for several years now without issue.
I had looked at that board at some point and certainly thought it was a good fit.
I was tempted to use a spare Win10 Pro licence I have laying around, but it's probably sensible to buy it from PCS, as I think a restricted level of support was mentioned.
That all looks super though and you kept within budget as well, genuinely appreciate that, you're very kind.
Also your note about transferring licences (MS) was something I wasn't aware of, excellent bit of info!
Superb stuff, thank you againThis is some more info on tying your windows 10 license to Microsoft account so you can transfer to other builds, works for home and pro, but obviously not volume licenses
How to link your Windows 10 product key to a Microsoft account
If you're using a local account, use this guide to link your Windows 10 product key to your Microsoft account for easier re-activation.www.windowscentral.com
Sorry, missed this response, many thanks again. It would be nice to have air, I've had Noctua before and find them brilliant.Further addition, if you really are set on air cooling, get the Noctua, nothing else is relevant with this chip.
Just to stress though, the chip won't perform at stated speeds under air, it won't reach max boost clocks, air just isn't sufficient.Sorry, missed this response, many thanks again. It would be nice to have air, I've had Noctua before and find them brilliant.
Thank you for that, Spyder, really appreciate the clarificationJust to stress though, the chip won't perform at stated speeds under air, it won't reach max boost clocks, air just isn't sufficient.
