Should I upgrade my laptop to 2x8GB or 1x16GB
SteveTrov
This is my current laptop:
Chassis & DisplayOptimus Series: 15.6" Matte Full HD IPS LED Widescreen (1920x1080)
Processor (CPU)Intel® Core™ i7 Quad Core Processor 7700HQ (2.8GHz, 3.8GHz Turbo)
Memory (RAM)8GB Corsair VENGEANCE 2400MHz SODIMM DDR4 (1 x 8GB)
Graphics CardNVIDIA® GeForce® GTX 1050 - 4.0GB GDDR5 Video RAM - DirectX® 12.1
1st Storage Drive480GB KINGSTON UV400 2.5" SSD, SATA 6 Gb (550MB/R, 500MB/W)
Memory Card ReaderIntegrated 6 in 1 Card Reader (SD /Mini SD/ SDHC / SDXC / MMC / RSMMC)
AC Adaptor1 x 120W AC Adaptor
Power Cable1 x 1 Metre Cloverleaf UK Power Cable
BatteryOptimus VIII Series 6 Cell Lithium Ion Battery
Sound CardIntel 2 Channel High Def. Audio + SoundBlaster™ Cinema 3
Bluetooth & WirelessGIGABIT LAN & WIRELESS INTEL® AC-8265 M.2 (867Mbps, 802.11AC) +BT 4.0, vPRO
USB/Thunderbolt Options1 x USB 3.0 PORT (Type C) + 2 x USB 3.0 PORTS + 1 x USB 2.0 PORT
Keyboard LanguageSINGLE COLOUR BACKLIT UK KEYBOARD
Operating SystemGenuine Windows 10 Home 64 Bit - inc DVD & Single Licence
Windows Recovery MediaWindows 10 (64-bit) DVD with paper sleeve
Office SoftwareNO OFFICE SOFTWARE
BrowserGoogle Chrome™
Build TimeStandard Build - Approximately 7 to 9 working days
My favourite game is a simulation game called factorio that puts limited strain on my graphics but it bottle-necked by memory and I have wanted to upgrade the memory for a while to 16 GB.
So would 2x8GB or 1x16GB better.
SteveTrov
by "matched pair" would it be sufficient for me to buy another "8GB Corsair VENGEANCE 2400MHz SODIMM DDR4" module? Or do they need to be someway factory matched (if so what are they being matched on)
You can try a single stick, but often it won't be compatible, it's always safest to get a matched pair.
Matched pair is ideal.
You can always try a single stick and see how it goes. You will want to make sure it has the same frequency and timings. CPU-Z's Memory and SPD tabs can give you the details. perhaps try and buy the same part number.
Even that's not a guarantee it'll work, but if you're happy to try, it could save you money and also be good for the environment. :)
PC specialist guarnteed that if I bought another DIMM from them it would be a matched pair for the one I already had installed. So I did and installed it today. CPUID CPU-Z confirms it is running in dual channel mode and I am getting noticeably better performance.
Thanks for your help guys.
Awesome!
