I've got an Ergotron MX arm holding up my Apple Studio monitor. It was originally bought for my 27" 5k iMac that I forgot to order with the VESA mount, so it was heavier than expected as I couldn't remove the extra 1KG of metal stand. That was about £150 almost 10 years ago.
Been on there since 2015, and the only 'droopiness' issue I had was when I tried to extend the arm too far...but there are allen-key bolts to admits the spring tension, but even at their max tension the 11kg iMac was right on the limit of what it would support with the arm fully extended. Once I adjusted it so that it was at slightly more acute angle it was fine...and has been since.
www.ergotron.com
I suppose your other option - if you're going to set it's position and leave it - would be a more solid + significantly cheaper wall mount?
MX Heavy Monitor Arm | Large Display Mount | Ergotron
Hone in on the best, ergonomic view with the MX Desk Monitor Arm. Easily move heavier monitors and all-in-one computers into the best viewing position—higher, lower, extended, retracted, tilt or 360-degree rotation—to help ward off eye, neck and back strain. Say no to the scroll and rotate your...
